savastakan wrote on Friday, November 21, 2008:
I am updating source code for freertos but I have some error,I don’t understand why I got these error,please help me ( freerots wrote for p33FJ256GP710,I want to modify for p30f6014A )
problem is :
port.c: In function ‘prvSetupTimerInterrupt’:
port.c:277: error: ‘TCON_16BIT’ has no member named ‘TCKPS0’
port.c:278: error: ‘TCON_16BIT’ has no member named ‘TCKPS1’
funciton is :
* Setup a timer for a regular tick.
static void prvSetupTimerInterrupt( void )
const unsigned portLONG ulCompareMatch = ( configCPU_CLOCK_HZ / portTIMER_PRESCALE ) / configTICK_RATE_HZ;
/* Prescale of 8. */
T1CON = 0;
TMR1 = 0;
PR1 = ( unsigned portSHORT ) ulCompareMatch;
/* Setup timer 1 interrupt priority. */
IPC0bits.T1IP = configKERNEL_INTERRUPT_PRIORITY;
/* Clear the interrupt as a starting condition. */
IFS0bits.T1IF = 0;
/* Enable the interrupt. */
IEC0bits.T1IE = 1;
/* Setup the prescale value. */
T1CONbits.TCKPS0 = 1;
T1CONbits.TCKPS1 = 0;
/* Start the timer. */
T1CONbits.TON = 1;
