I am trying to port Amazon FreeRTOS logging function to Atmel SAM4E Xplained pro.
I initialized the heap memory as we are using dynamic buffers.
Whenever the configPRINTF is called, I can see the debug messages in Atmel Studio 7.0.
in aws_logging_task_dynamic_buffers.c :
I can see that string is being stored in the dynamic memory when this function is called:
Regarding configuration,
the constants INCLUDE_xTaskGetSchedulerState , configUSE_TIMERS and configUSE_QUEUE_SETS are set to 1.
0xa5a5a5a5 is the literal address I see everytime.
I see this when the function is called, the state of variables are:
pvBuffer 0x2000b2c8 <uxTimerTaskStack.12207+440>
pxQueue 0x200007d0 <xStaticTimerQueue.6631>
Off hand, that’s not the queue for the logging task.
Note there will be multiple queues in operation at any given time.
Can you check to see if xQueueReceive is called with xQueue from aws_logging_task_dynamic_buffers.c? You may want to rename that variable to make it easier to check for in the debugger.
If xQueueReceive is never called on the logging queue, then it may be that the logging task is not running.
Are you able to give us more information about the port you are working on?
Can I also ask what specifically is pointing to 0xA5A5A5A5?
Is it xQueue? pxQueue? pvBuffer? Or one of the member variables for pxQueue?
0xA5A5A5A5 is what we initialize the stack memory to (
stack_macros.h
). So, that indicates that you’re looking at an uninitialized variable. And so, I am trying to figure out a bit more about which variable is uninitialized.
