apullin2 wrote on Wednesday, October 29, 2014:
Hi there,
I’m starting to get my application to actually run on my chip. I’m beaming with excitement.
The one trick is that I’m using heap_4.c, since the platform does a lot of allocations and frees, since there’s a radio chip that sends variable length payloads all the time.
The issue that I’m running in to is that on the dsPIC33 chip I have, which has 16K of RAM, only the lower 8K of it is available via ‘near’ addressing.
I want to allocate a large heap, most of what is not used in regular task tasks, to facilitate large queues for communications stacks.
Can you foresee any problems with changing the declaration of ucHeap to have _attribute_ ((far)) ?
Relevant chip-specific information is here, page 37, section 4.2.4 :
http://ww1.microchip.com/downloads/en/DeviceDoc/70594d.pdf
It looks like points aren’t any extra words in length, and the compiler has to issue an extra move instruction for any pointer deref? Getting a bit out of my depth there.
