I’m using FreeRTOS on a dsPIC33 MCU. When compiling a demo project I’m getting the following error in heap_1.c
../../FreeRTOS/FreeRTOSV8.2.3/FreeRTOS/Source/portable/MemMang/heap_1.c: In function 'pvPortMalloc':
../../FreeRTOS/FreeRTOSV8.2.3/FreeRTOS/Source/portable/MemMang/heap_1.c:124:30: warning: cast to pointer from integer of different size
When I look at the definition of portPOINTER_SIZE_TYPE, it is uint32_t; however, the pointer size on the dsPIC33 is actually 16-bits, for both data (16 bits) or program memory (24 bits, it puts handles to functions if they aren’t in the first 16-bit addreesable 64k).
Is this intentional? If so, what is the purpose of defining portPOINTER_SIZE_TYPE that way?
portPOINTER_SIZE_TYPE was inroduced to solve this compiler warning on some 8 and 16-bit devices that required it - so you will see ports such as MPS430X, RL78, etc. have a genuine definition. I think the dsPIC port pre-dates the introduction of the constant, so what you are seeing is it default to 32-bits if it is not otherwise defined.
Thanks for the quick reply. I’m still getting familiar with FreeRTOS, so does that mean I can safely change the portPOINTER_SIZE_TYPE to uint16_t, or should I just leave it as it is and ignore the warning?
It is safe to leave it as it is, as the bits that get truncated cannot
possibly hold any data. Setting it to uint16_t should be fine, its just
not tested (assuming pointers cannot be 24-bits?).
