johughes2002 wrote on Monday, July 28, 2008:
I’m having some issues getting the kernel running on my STR730 board. I started with the STR75x GCC port and demo, modified for the differences in periferal api to provide the tick interrupt, and have everything compiled and flashed to the board. The problem I’m having is on when starting the scheduler. I’ve stepped through the code, and invariably I get an abort exception in vPortISRStartFirstTask() which from the STR75x port contains some inline ASM which I think sets the MCU registers up for starting the first task:
<pre>
void vPortISRStartFirstTask( void )
/* Simply start the scheduler. This is included here as it can only be
called from ARM mode. */
asm volatile (
"LDR R0, =pxCurrentTCB \n\t"
"LDR R0, [R0] \n\t"
"LDR LR, [R0] \n\t" \
/* The critical nesting depth is the first item on the stack. */
/* Load it into the ulCriticalNesting variable. */
"LDR R0, =ulCriticalNesting \n\t"
"LDMFD LR!, {R1} \n\t"
"STR R1, [R0] \n\t"
/* Get the SPSR from the stack. */
"LDMFD LR!, {R0} \n\t"
"MSR SPSR, R0 \n\t"
/* Restore all system mode registers for the task. */
"LDMFD LR, {R0-R14}^ \n\t"
"NOP \n\t"
/* Restore the return address. */
"LDR LR, [LR, #+60] \n\t"
/* And return - correcting the offset in the LR to obtain the */
/* correct address.
"SUBS PC, LR, #4 \n\t"
</pre>
The MCU aborts after the last line, which sets the PC to somewhere whack out of range.
I dumped the registers after it loads them from the stack. These look like the values set on the stack in pxPortInitialiseStack(). It looks like something isn’t right with LR. Am I right in thinking it’s somehow loaded LR with data in the wrong position on the stack, or should it look like that?
<pre>
r0 0x0 0
r1 0x1010101 16843009
r2 0x2020202 33686018
r3 0x3030303 50529027
r4 0x4040404 67372036
r5 0x5050505 84215045
r6 0x6060606 101058054
r7 0x7070707 117901063
r8 0x8080808 134744072
r9 0x9090909 151587081
r10 0x10101010 269488144
r11 0x11111111 286331153
r12 0x12121212 303174162
sp 0xa00002d0 0xa00002d0
lr 0xaaaaaaaa 2863311530
pc 0x80000f28 0x80000f28 <vPortISRStartFirstTask+40>
fps 0x0 0
cpsr 0x400000df 1073742047
</pre>
Any hints would be appreciated. I’ve been tearing my hair out for the past few days on this.
Thanks
