Is there a freeRTOS conformance test suite for R52?
Our solution uses freeRTOS running on R52 processor, as R52 doesnt natively support freeRTOS, we want to verify all freeRTOS functionality against our codebase running in R52.
Do we have any test suit covering this? we just need to ensure all RTOS functionality like context switch, tasks, stacks and so on are thoroughly validated.
Can someone please suggest? thanks.
You can use soak tests as described here: FreeRTOS/FreeRTOS/Demo/ThirdParty/Template at main · FreeRTOS/FreeRTOS · GitHub.
Are you not able to use CR5 port?
