sam-system wrote on Wednesday, June 04, 2008:
I’m trying to use FreeRTOS together with C++.
I’m using IAR AVR compiler.
All of FreeRTOS source files are compiled using the C compiler and my own code using Extended Embedded C++ compiler. All the code are compiled and linked togther without errors.
Inspired by a richard_damon post I’ve made a Runable class, see below.
Running my code I get an RStack warning (JTAGICE mkII)
Wed Jun 04 11:49:06 2008: Target reset
Wed Jun 04 11:49:16 2008: Program exit reached.
Wed Jun 04 11:49:17 2008: The stack ‘RStack’ is filled to 100% (32 bytes used out of 32). The warning threshold is set to 90.%
I’ve traced it down to being this static_cast causing the trouble.
(static_cast<Runable*>(parm))->Run();
If I comment the static_cast and uncomment the loop causing a led to flash everything works fine.
I have tried the same code using winavr c++ compiler and it works. Using the winavr compiler I compile everything using the c++ compiler. Therefore I have to change some cast here and there in the FreeRTOS code in order to satisfy the c++ compiler. When using IAR I can compile a "clean" FreeRTOS (without changing anything) using C compiler and my own code using C++. My guess is that its the reason for my troubles.
Can someone give me an explanation or even a way to fix it?
/Thomas
// runable.c
#include "runable.h"
Runable::Runable(unsigned priority, unsigned stacksize)
#if INCLUDE_vTaskDelayUntil
lastWakeTime = NULL;
xTaskCreate(&run, "", stacksize, this, priority, &handle);
Runable::~Runable()
#if INCLUDE_vTaskDelete
vTaskDelete(handle);
#if INCLUDE_vTaskSuspend
void Runable::Suspend()
vTaskSuspend(handle);
void Runable::Resume()
vTaskResume(handle);
void Runable::Sleep(portTickType delay)
vTaskDelay(delay);
void Runable::SleepUntil(portTickType increment)
if (lastWakeTime == NULL)
lastWakeTime = xTaskGetTickCount();
vTaskDelayUntil(&lastWakeTime, increment);
void Runable::run(void* parm)
for(;
PORTA = (PORTA & ~0x01) | (~PORTA & 0x01);
vTaskDelay( 100 );
