Hello everyone
I am looking help on Free RTOS. I have been reading some materials and have been reading book but still I am having problem to understand basic of RTOS. so I have decided to start with small project. I know RTOS is mainly design for Time based reuirenment. just for practice why not start with LED. I know how to blink LED with C program. Now I want to blink LED under Free RTOS. I understand I don’t need rtos to blink LED but it is just for practice so that I can understand at least which header and source file of Free RTOS I can use to Blink LED. once I blink LED under control of RTOS. after that I will do come complex projcet. so please help me
The best way I think to do this is to look through the projects that are
available to download, find one that uses your IDE then buy a dev board
to go with that project.
Once you have that, compile and run the demo project and write a very
simple thread that toggles an LED. If you’ve done any sort of reading,
you’ll have found plenty of tutorials on creating a thread, using task
delays etc.
In essence, the way I look at it is that a thread is like a
run-to-complete infinite loop style piece of software you’re used to
writing for micros. You can write a number of threads that can run
[seemingly] concurrently and communicate with each other.
Once you have your LED flashing you can do things like write a thread
that gathers serial information then pass it via a queue to another
thread that processes that information. You’ll then soon get the hang of
how it all works and do some real world stuff.
On 20/07/17 16:41, vead wrote:
Hello everyone
please help me
If you have been reading the official book (free pdf download), or the
API documentation for the functions that show you exactly what you are
asking (http://www.freertos.org/a00127.html), then its hard to add
anything additional. You can look at examples though. Here is a really
old file that just flashes LEDs at different rates. It is included in
most of the examples in the FreeRTOS download, if you have looked at
those too:
Thanks for your reply I have downloaded some projects and books. I have gone through given links but my confusen is on selection of header files and sources
suppose I want to flesh three LEDs at different rate. first LED flashes every 200ms, the second every 400ms, the third every 600ms. how many header files and source files I need in program. can you tell me the name of header files and source files.
Open an existing project to see, or better still read the online documentation or book chapter that tells you how to create a new project, including which files to build and which include paths to add.
as said I have been reading book and looking some project examples but I don’t understand the idea which files I need to add and built in program. may be my poor understanding. I am not asking for complete program. I am stuck at starting for selection of free RTOS files. I don’t know why you didn’t give the answer of my question for LEDs. if possible can you give me the name of files which I have to add and build in program so that I can go for further learning
You don’t need anything else if you download the source code and use
one of the demo projects, This is why we’re saying get a demo project.
The download instructions are here.
Choose one for your IDE and compile it. It will just work. No extra
files needed. This is the beauty of starting with a demo project.
I don’t know how to explain. ok I am using cortex M3 and keil compiler and I have downloaded some project. now If I don’t want use demo projcet I want to mak my own project (flesh Three LEDs at different rate ) than How to do it
in program.
…and I referenced this page, which tells you, as does the book:
LEDs.
…and I referenced this page, which is an LED flashing example, and
told you which file in the FreeRTOS download contains more examples:
I don’t think I could do more than reference the pages that provide
answers to your questions, other than cut and paste content from those
pages into the forum.
