nboubaker wrote on Thursday, May 15, 2014:
Using FreeRTOSV7.5.0 and eclipse for DS-5 renesas
How to buil and test a FreeRTOS-Plus demo for example FreeRTOS-Plus-UDP on eclipse for DS-5 renesas?
rtel wrote on Thursday, May 15, 2014:
Why are you using such an old version?
I would suggest the following:
Ensure you DS-5 FreeRTOS project is building, debugging and executing on your target hardware.
Add the FreeRTOS+UDP source files into the project. Basically all the files that reside outside the portable layer. You can look at the projects files used by the demos for a reference:
http://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_UDP/Embedded_Ethernet_Examples/RTOS_UDP_CLI_Windows_Simulator.shtml
http://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_UDP/Embedded_Ethernet_Examples/RTOS_UDP_and_CLI_LPC1830_NGX.shtml
Implement the macros that are necessary to build the code with DS-5 as described here:
http://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_UDP/Embedded_Compiler_Porting.shtml
Implement the MAC interface as described here:
http://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_UDP/Embedded_Ethernet_Porting.shtml
http://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_UDP/Network_interface_functions.shtml
again, you can use the demo projects for references.
