heinbali01 wrote on Monday, June 03, 2019:
HI Johannes,
First: I would let these tasks take control of the situation, let the task decide when a connection is considered dead.
You can control the maximum blocking time per API. That is documented on freertos.org/tcp
#define FREERTOS_SO_RCVTIMEO ( 0 ) /* Used to set the receive time out. */
#define FREERTOS_SO_SNDTIMEO ( 1 ) /* Used to set the send time out. */
FreeRTOS+TCP has mechanisms to detect an orphaned connection, which happens when the peer has left without a graceful closure.
/* Include support for TCP hang protection. All sockets in a connecting or
disconnecting stage will timeout after a period of non-activity. */
#define ipconfigTCP_HANG_PROTECTION ( 1 )
#define ipconfigTCP_HANG_PROTECTION_TIME ( 30 )
/* Include support for TCP keep-alive messages. */
#define ipconfigTCP_KEEP_ALIVE ( 1 )
#define ipconfigTCP_KEEP_ALIVE_INTERVAL ( 20 ) /* in seconds */
If possible, it is even better to implement this protection at a higher level: send a are-you-alive (AYA) message at regular intervals to check if the connection is still OK.
These messages only have to be sent as long as there is no other traffic.
I think there is no need to detect and kill ghost tasks: make them responsible for their connections and let them kill them selves when done.
Security: I sometimes do have a (software) watchdog that must be touched regularly by all tasks, e.g. every minute. But when that watchdog goes off, it’s like an exception: it will cause a reset of the CPU, and the event will be reported.
If you have plenty of resources, it’s fine to handle one socket per task. But if you have little RAM, you can use one of the many techniques to handle a who set of socket within one task. Think of:
/* Use FreeRTOS_select() */
#define ipconfigSUPPORT_SELECT_FUNCTION 1
/* Use call-backs */
#if ipconfigUSE_CALLBACKS == 1
#define FREERTOS_SO_TCP_CONN_HANDLER ( 6 ) /* Install a callback for (dis) connection events */
#define FREERTOS_SO_TCP_RECV_HANDLER ( 7 ) /* Install a callback for receiving TCP data */
#define FREERTOS_SO_TCP_SENT_HANDLER ( 8 ) /* Install a callback for sending TCP data */
#define FREERTOS_SO_UDP_RECV_HANDLER ( 9 ) /* Install a callback for receiving UDP data */
#define FREERTOS_SO_UDP_SENT_HANDLER ( 10 ) /* Install a callback for sending UDP data */
#endif /* ipconfigUSE_CALLBACKS */
/* Connect each socket with a semaphore. */
#if( ipconfigSOCKET_HAS_USER_SEMAPHORE == 1 )
#define FREERTOS_SO_SET_SEMAPHORE ( 3 ) /* Used to set a user's semaphore */
The above is all documented on freertos.org/tcp and often discussed on this forum.
