I am using EK-RA6M3 to test TCPIP communication with FreeRTOS + TCP.
The following functions are executed repeatedly.
FreeRTOS_accept()
FreeRTOS_setsockopt()
FreeRTOS_recv()
FreeRTOS_send()
FreeRTOS_shutdown()
vPortFree()
FreeRTOS_closesocket()
If the client disconnects during FreeRTOS_recv(), it jumps to prvTaskExitError().
If I stop debugging and run it again, I cannot connect with FreeRTOS_accept().
When I stop debugging and then run it again, I cannot connect with FreeRTOS_accept().
I cannot connect even when I power cycle the board, but I can connect by restarting the PC.
Please let me know if you know the correct procedure for stopping.
After calling FreeRTOS_shutdown(), are you making sure that shutdown is completed by calling FreeRTOS_recv to see if it returns -pdFREERTOS_ERRNO_EINVAL.
Yes, pdFREERTOS_ERRNO_ENOTCONN is returned if either the connection has been closed or in the process of closing, ie, waiting for a connection termination request or waiting for a connection termination request acknowledgement from the remote TCP.
void TaskFunction( void * params )
( void ) params;
/* Perform task functions. */
/* Delete the task as we no longer need it. */
vTaskDelete( NULL );
One of the break statements in your code causes it to exit the task function which is the cause of the error. Here is the updated code - new_thread0_entry.c (5.9 KB). Hope that helps.
