pinnor wrote on Friday, January 04, 2008:
Hi to all, after a lot of work I was able to compile correctly the DemoRTOS software on my system: mcb2300 board with lpc2368 + Eclipse + yagarto gcc tools + openocd + jtagkey, but i still have a problem.
I’am able to start the openocd server using this config file:
#daemon configuration
telnet_port 4444
gdb_port 3333
#interface
interface ft2232
ft2232_device_desc "Amontec JTAGkey A"
ft2232_layout jtagkey
ft2232_vid_pid 0x0403 0xcff8
jtag_nsrst_delay 100
jtag_speed  10
#jtag_speed 20
#jtag_nsrst_delay 500
#jtag_ntrst_delay 500
#jtag_speed 10
#jtag_nsrst_delay 100
#jtag_ntrst_delay 100
#use combined on interfaces or targets that can’t set TRST/SRST separately
reset_config trst_and_srst srst_pulls_trst
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 4 0x1 0xf 0xe
#target configuration
daemon_startup reset
#target <type> <startup mode>
#target arm7tdmi <reset mode> <chainpos> <endianness> <variant>
target arm7tdmi little run_and_halt 0 arm7tdmi-s_r4
run_and_halt_time 0 30
working_area 0 0x40000000 0x4000 nobackup
#flash configuration
#flash bank lpc2000 <base> <size> 0 0 <target#> <variant>
flash bank lpc2000 0x0 0x40000 0 0 0 lpc2000_v1 14765 calc_checksum
# For more information about the configuration files, take a look at:
# http://openfacts.berlios.de/index-en.phtml?title=Open+On-Chip+Debugger
and when i start it i get this message: (is it ok)
Info:    openocd.c:93 main(): Open On-Chip Debugger (2007-12-30 17:00 CET) svn: 247
Info:    openocd.c:94 main(): $URL: http://svn.berlios.de/svnroot/repos/openocd/trunk/src/openocd.c $
Info:    jtag.c:1291 jtag_examine_chain(): JTAG device found: 0x4f1f0f0f (Manufacturer: 0x787, Part: 0xf1f0, Version: 0x4)
Warning: embeddedice.c:175 embeddedice_build_reg_cache(): EmbeddedICE version 7 detected, EmbeddedICE handling might be broken
Warning: arm7_9_common.c:742 arm7_9_assert_reset(): srst resets test logic, too
But the problem happens when I try to enter in debug mode downloading the demo project…the process freeze on 57% progress, and these are the messages on my console:
Can sameone help me?
Regards,
Renato
