I have have downloaded the latest version of FreeRTOS. i wanted to port it to HCS12X controller.
I found on the unsupported ports a port for the HCS12X using CodeWarrior made tried to unzip that file. It asks for some password.hence i am unable to use that port…anyone knows about the password or is there any other way to use this HCs12X port.
I just tried opening the .zip file HCS12_HCS12X_CodeWarrior_OAF.zip from the FreeRTOS/Demo/Unsupported folder, and was not asked for a password. Is this the file you are using?
Hi Richard, Thanks for replying.
Yes i am using the same zip file.
The FreeRTOS version i am using is FreeRTOSV5.4.0.
Can u please tell me how did u unzip it. and which is the Codewarrior version u are using because if i skip the password and unzip the file. I gat a partially unzipped folder. And when i later open the project under CodeWarrior V4.6, it says project cannot be opened.
