hardfault with sprintf/snprintf/vsprintf/vsnprintf, newlib, newlibnano, tinyprintf
luk1990 wrote on Thursday, October 05, 2017:
Hello
Im having quite trouble finding the reason for my current hardfault.
Im using freertos with static memory allocation (no malloc ever used) i use new with pre allocated buffers (new (&buffer).
i have made sure that all threads are are aligned(4).
whenever i use a form of printf, my application jumps to the hardfault from the freertos call “start first task”.
i write “embedded C++” code, what is basically C89 with namespaces and classes, so nothing other than is included from c++. each include from c files (.h) are wrapped with extern “C” so there is never ever a linkage issue.
i have tested with newlib, newlib nano and the tinyprintf from spare time libs. no difference.
also, i have never an assert failure on the malloc calls, so i am “quite” sure no newlib function accesses malloc (am i right here?)
the internet suggests its either a dynamic memory allocation issue or a stack issue. how can i prove what is causing the hardfault? i believe the hint my stack gets corrupted because of my printf calls isnt that wrong. how can i prove this? (i have never debugged stacks and would need some help debugging the stack pointer).
any other ideas?
thank you very much
example:
  (void) vsnprintf( _log_buffer, C_LOG_BUFFER_SIZE, format, args ); // hardfault
  (void) sprintf( _log_buffer, "huhu" ); // no hardfault
dynamic allocation overwrites:
__ATL_LINK_EXTERN_C void *malloc( size_t size )
  (void) size;
  atl::os::assert::failed((char*)__FILE__,__LINE__);
  return NULL;
__ATL_LINK_EXTERN_C void * calloc(size_t size1, size_t size2)
  (void) size1;
  (void) size2;
  return NULL;
__ATL_LINK_EXTERN_C void *realloc(void * ptr, size_t size)
  (void) ptr;
  (void) size;
  return NULL;
__ATL_LINK_EXTERN_C void free( void * ptr )
  (void) ptr;
freertos config:
    FreeRTOS V9.0.0 - Copyright (C) 2016 Real Time Engineers Ltd.
    All rights reserved
    VISIT http://www.FreeRTOS.org TO ENSURE YOU ARE USING THE LATEST VERSION.
    This file is part of the FreeRTOS distribution.
    FreeRTOS is free software; you can redistribute it and/or modify it under
    the terms of the GNU General Public License (version 2) as published by the
    Free Software Foundation >>!AND MODIFIED BY!<< the FreeRTOS exception.
    >>!   NOTE: The modification to the GPL is included to allow you to     !<<
    >>!   distribute a combined work that includes FreeRTOS without being   !<<
    >>!   obliged to provide the source code for proprietary components     !<<
    >>!   outside of the FreeRTOS kernel.                                   !<<
    FreeRTOS is distributed in the hope that it will be useful, but WITHOUT ANY
    WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
    FOR A PARTICULAR PURPOSE.  Full license text is available on the following
    link: http://www.freertos.org/a00114.html
     *    FreeRTOS provides completely free yet professionally developed,    *
     *    robust, strictly quality controlled, supported, and cross          *
     *    platform software that is more than just the market leader, it     *
     *    is the industry's de facto standard.                               *
     *    Help yourself get started quickly while simultaneously helping     *
     *    to support the FreeRTOS project by purchasing a FreeRTOS           *
     *    tutorial book, reference manual, or both:                          *
     *    http://www.FreeRTOS.org/Documentation                              *
    http://www.FreeRTOS.org/FAQHelp.html - Having a problem?  Start by reading
	the FAQ page "My application does not run, what could be wrong?".  Have you
	defined configASSERT()?
	http://www.FreeRTOS.org/support - In return for receiving this top quality
	embedded software for free we request you assist our global community by
	participating in the support forum.
	http://www.FreeRTOS.org/training - Investing in training allows your team to
	be as productive as possible as early as possible.  Now you can receive
	FreeRTOS training directly from Richard Barry, CEO of Real Time Engineers
	Ltd, and the world's leading authority on the world's leading RTOS.
    http://www.FreeRTOS.org/plus - A selection of FreeRTOS ecosystem products,
    including FreeRTOS+Trace - an indispensable productivity tool, a DOS
    compatible FAT file system, and our tiny thread aware UDP/IP stack.
    http://www.FreeRTOS.org/labs - Where new FreeRTOS products go to incubate.
    Come and try FreeRTOS+TCP, our new open source TCP/IP stack for FreeRTOS.
    http://www.OpenRTOS.com - Real Time Engineers ltd. license FreeRTOS to High
    Integrity Systems ltd. to sell under the OpenRTOS brand.  Low cost OpenRTOS
    licenses offer ticketed support, indemnification and commercial middleware.
    http://www.SafeRTOS.com - High Integrity Systems also provide a safety
    engineered and independently SIL3 certified version for use in safety and
    mission critical applications that require provable dependability.
    1 tab == 4 spaces!
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
 * Application specific definitions.
 * These definitions should be adjusted for your particular hardware and
 * application requirements.
 * THESE PARAMETERS ARE DESCRIBED WITHIN THE 'CONFIGURATION' SECTION OF THE
 * FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
 * See http://www.freertos.org/a00110.html.
/* USER CODE BEGIN Includes */
/* Section where include file can be added */
/* USER CODE END Includes */
/* Ensure stdint is only used by the compiler, and not the assembler. */
#if defined(__ICCARM__) || defined(__CC_ARM) || defined(__GNUC__)
    #include <stdint.h>
    extern uint32_t SystemCoreClock;
/* USER CODE BEGIN 0 */
    extern void configureTimerForRunTimeStats(void);
    extern unsigned long getRunTimeCounterValue(void);
/* USER CODE END 0 */
#define configUSE_PREEMPTION                     1
#define configSUPPORT_STATIC_ALLOCATION          1
#define configSUPPORT_DYNAMIC_ALLOCATION         0
#define configUSE_IDLE_HOOK                      1
#define configUSE_TICK_HOOK                      1
#define configCPU_CLOCK_HZ                       ( SystemCoreClock )
#define configTICK_RATE_HZ                       ((TickType_t)1000)
#define configMAX_PRIORITIES                     ( 7 )
#define configMINIMAL_STACK_SIZE                 ((uint16_t)32) // MOD was 128
#define configMAX_TASK_NAME_LEN                  ( 32 ) // mod was 16
#define configGENERATE_RUN_TIME_STATS            1
#define configUSE_TRACE_FACILITY                 1
#define configUSE_STATS_FORMATTING_FUNCTIONS     1
#define configUSE_16_BIT_TICKS                   0
#define configUSE_MUTEXES                        1
#define configQUEUE_REGISTRY_SIZE                8
#define configCHECK_FOR_STACK_OVERFLOW           1
#define configUSE_MALLOC_FAILED_HOOK             1
#define configUSE_DAEMON_TASK_STARTUP_HOOK       1
#define configUSE_PORT_OPTIMISED_TASK_SELECTION  1
/* Co-routine definitions. */
#define configUSE_CO_ROUTINES                    0
#define configMAX_CO_ROUTINE_PRIORITIES          ( 2 )
/* Software timer definitions. */
#define configUSE_TIMERS                         1
#define configTIMER_TASK_PRIORITY                ( 2 )
#define configTIMER_QUEUE_LENGTH                 10
#define configTIMER_TASK_STACK_DEPTH             256
#define INCLUDE_vTaskPrioritySet            1
#define INCLUDE_uxTaskPriorityGet           1
#define INCLUDE_vTaskDelete                 1
#define INCLUDE_vTaskCleanUpResources       1
#define INCLUDE_vTaskSuspend                1
#define INCLUDE_vTaskDelayUntil             1
#define INCLUDE_vTaskDelay                  1
#define INCLUDE_xTaskGetSchedulerState      1
#define INCLUDE_xTimerPendFunctionCall      1
#define INCLUDE_xQueueGetMutexHolder        1
#define INCLUDE_xSemaphoreGetMutexHolder    1
#define INCLUDE_pcTaskGetTaskName           1
#define INCLUDE_uxTaskGetStackHighWaterMark 1
#define INCLUDE_xTaskGetCurrentTaskHandle   1
#define INCLUDE_eTaskGetState               1
#define INCLUDE_xTaskAbortDelay             1
#define INCLUDE_xTaskGetHandle              1
/* Cortex-M specific definitions. */
#ifdef __NVIC_PRIO_BITS
 /* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
 #define configPRIO_BITS         __NVIC_PRIO_BITS
#else
 #define configPRIO_BITS         4
function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY   15
routine that makes calls to interrupt safe FreeRTOS API functions.  DO NOT CALL
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
/* Interrupt priorities used by the kernel port layer itself.  These are generic
#define configKERNEL_INTERRUPT_PRIORITY 		( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
#define configMAX_SYSCALL_INTERRUPT_PRIORITY 	( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
/* Normal assert() semantics without relying on the provision of an assert.h
header file. */
/* USER CODE BEGIN 1 */
#define configASSERT( x ) if ((x) == 0) {taskDISABLE_INTERRUPTS(); for( ;; );}
/* USER CODE END 1 */
/* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
standard names. */
#define vPortSVCHandler    SVC_Handler
/* IMPORTANT: This define MUST be commented when used with STM32Cube firmware,
              to prevent overwriting SysTick_Handler defined within STM32Cube HAL */
/* #define xPortSysTickHandler SysTick_Handler */
/* USER CODE BEGIN 2 */
/* Definitions needed when configGENERATE_RUN_TIME_STATS is on */
#define portCONFIGURE_TIMER_FOR_RUN_TIME_STATS configureTimerForRunTimeStats
#define portGET_RUN_TIME_COUNTER_VALUE getRunTimeCounterValue
/* USER CODE END 2 */
/* USER CODE BEGIN Defines */
/* Section where parameter definitions can be added (for instance, to override default ones in FreeRTOS.h) */
/* USER CODE END Defines */
rtel wrote on Saturday, October 07, 2017:
Sorry for the late reply, but your post went into moderation, which its not supposed to do.
I would recommend setting configCHECK_FOR_STACK_OVERFLOW to 2 rather than 1, but other than that, you have the ‘normal’ suggestions covered already (like having configASSERT() defined). I can’t comment on the C++ stuff though as we only test in C projects - although there are lots of people using FreeRTOS with C++. Stack overflow is the most common issue with the printf() family of functions.
Have you tried debugging the hard fault? http://www.freertos.org/Debugging-Hard-Faults-On-Cortex-M-Microcontrollers.html
gourmetsel wrote on Monday, October 09, 2017:
The link provided above helped us some months ago to find the cause of a hard fault.
We ported software from one processor to another from the same family. The problem in our case was the maximum clock frequency being exceeded. This did not lead to an immediate hard fault.
Are you sure the calls to printf are actually the problem? Is your code running flawlessly without these calls?
Regarding your question on stack overflow, this page is also a good read: http://www.freertos.org/Stacks-and-stack-overflow-checking.html
If you have ways to examine your memory when single-stepping through your code, you could also check your task stack at task creation and after you ran into the hard fault. This should give you a first indication whether you run into an overflow.
heinbali01 wrote on Tuesday, October 10, 2017:
Hi, if you think that the problem is in vsnprintf(), you may want to try this version of printf-stdarg.c which is part of the of the FreeRTOS+TCP library. Just link it into your project and provide the 2 functions described in my post.
Some questions to you:
  • does that function alway crash?
  • can you show us some code that calls vsnprintf()?
  • how did you implement C++ new method?
  • do you use printf() function from within an ISR?
