zzattack wrote on Tuesday, November 20, 2018:
On my STM32F091 project I’m encountering a HardFault. Frequency of occurence is about weekly. I’m looking for some help debugging this issue as I haven’t been able to reveal the source yet.
The program jumps to the hardfault handler during a printf call. This is evident from the serial port debug output. When the hardfault occurs, the code line
sync_printf("State changed from %d -> %d\n", cur_state, new_state);
is interrupted halfway and prints
State changed from HardFault_HandlerC():
For context, all my printf calls are surrounded with a mutex block so tasks’ debug output remains coherent:
int sync_printf(const char* format, ...) {
va_list args;
va_start(args, format);
int v = 0;
if (osMutexWait(pf_lock, osWaitForever) == osOK) {
v += print(0, format, args);
osMutexRelease(pf_lock);
va_end(args);
return v;
I don’t believe this to cause issues but figure it needs to be mentioned.
Bunch of things I tried in order to reveal the root cause:
- used a different, malloc-free, printf version (this one is printf-stdarg), but hardfault happens in exactly the same place with newlib-nano printf
- configCHECK_FOR_STACK_OVERFLOW=2, configUSE_MALLOC_FAILED_HOOK=1, configASSERT is defined
- the vApplicationStackOverflowHook and vApplicationMallocFailedHook hooks are defined but not called
- expanded my tasks’ stack sizes significantly to rule out stack overflowing issue
- using heap scheme 4 so no malloc/free
Here’s some info from the stack when the hardfault occurs. I’m unsure how to interpret this; my knowledge on the architecture is minimal.
stacked_r0: 0x00000020
stacked_r1: 0x20006fe3
stacked_r2: 0x20004405
stacked_r3: 0x20004401
stacked_r12: 0x36c398e5
stacked_lr: 0x08005fa1
stacked_pc: 0x08011a56
stacked_psr: 0x01000000
CFSR: 0x00000000
HFSR: 0x00000000
DFSR: 0x00000000
AFSR: 0x00000000
MMAR: 0x00000000
BFAR: 0x00000000
The stacked_pc @ 0x08011a56 points inside the ‘print’ function in the disassembly:
if (*format == 'd') {
0x08011a48 BB 68 ldr r3, [r7, #8]
0x08011a4a 1B 78 ldrb r3, [r3, #0]
0x08011a4c 64 2B cmp r3, #100 ; 0x64
0x08011a4e 0F D1 bne.n 0x8011a70 <print+312>
pc += printi(out, va_arg(args, int), 10, 1, width, pad, 'a');
0x08011a50 7B 68 ldr r3, [r7, #4]
0x08011a52 1A 1D adds r2, r3, #4
0x08011a54 7A 60 str r2, [r7, #4]
0x08011a56 19 68 ldr r1, [r3, #0]
0x08011a58 F8 68 ldr r0, [r7, #12]
0x08011a5a 61 23 movs r3, #97 ; 0x61
0x08011a5c 02 93 str r3, [sp, #8]
0x08011a5e 01 96 str r6, [sp, #4]
0x08011a60 00 95 str r5, [sp, #0]
0x08011a62 01 23 movs r3, #1
0x08011a64 0A 22 movs r2, #10
0x08011a66 FF F7 EB FE bl 0x8011840 <printi>
0x08011a6a 03 00 movs r3, r0
0x08011a6c E4 18 adds r4, r4, r3
continue;
0x08011a6e 5F E0 b.n 0x8011b30 <print+504>
The printing functions are taken from https://github.com/atgreen/FreeRTOS/blob/master/Demo/CORTEX_STM32F103_Primer_GCC/printf-stdarg.c
Any guidance on finding the root cause or obtaining more information in order to be able to do so is highly appreciated.
Frank
