This is my first post in this forum . So please be nice.
Currently I try to migrate a freertos project which was built in Xilinx SDK 2013.4 to new version 2015.3 .
When I re-generated the new freetos bsp ffrom the tool. I got this error when running the freertos tcl. Not sure if I should make a change in this tcl or not.
Any idea,
Thanks
09:55:25 ERROR : (XSDB Server)ERROR: [Hsi 55-1545] Problem running tcl command ::sw_freertos_zynq_v1_00_a::FreeRTOS_drc : invalid command name “xget_libgen_proc_handle”
while executing
(procedure “::sw_freertos_zynq_v1_00_a::FreeRTOS_drc” line 5)
invoked from within
“::sw_freertos_zynq_v1_00_a::FreeRTOS_drc freertos_zynq”
09:55:26 ERROR : Error generating bsp sources: Failed in generating sources
09:55:26 ERROR : Failed to regenerate sources for BSP project freertos_zynq_bsp_0
org.eclipse.core.runtime.CoreException: Internal error occurred while generating bsp sources. Please check the SDK Log view for further details.
at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.internalGenerateBsp(RegenBspSourcesHandler.java:178)
at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.access$2(RegenBspSourcesHandler.java:163)
at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1$1.run(RegenBspSourcesHandler.java:131)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2345)
at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1.run(RegenBspSourcesHandler.java:135)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
We’re always nice on this forum
Unfortunately I don’t understand what goes wrong in your SDK 2015.3. It looks like a question for the Xilinx forum or maybe Eclipse.
Are you able to create the Xilinx sources ( xxx__bsp\ps7_cortexa9_0\libsrc\* ) ?
I see that I’m running behind, I’m still using 2015.2.
There are some alternative ways if you want:
Use a Makefile project
Use the FreeRTOS Zynq project
Try the eariler SDK 2015.2
Makefile: see File → Import → Select an import source → type “Makefile”
and you will see the option “Existing Code as Makefile Project”.
Using a Makefile will give you total freedom: you can also include FreeRTOS and the BSP files in the Makefile.
Use the FreeRTOS Zynq project : on www.freertos.org/labs you find a project using +TCP and +FAT that is ready to run on a Zynq. It will only need the creation of the Xilinx BSP files. Once you have this project compiling and running, you can replace the project sources with your own sources.
I presume this question is about using a FreeRTOS BSP, where the FreeRTOS source files are included in the files generated by the SDK, rather than a standalone BSP, where the FreeRTOS source files are built as part of the application.
Where are you getting the FreeRTOS BSP from? The TCP format/commands used by the 2013.4 SDK are not compatible with the 2014.x versions. I believe the latest SDK download has everything you need built in - so you do not need to add a repository. Alternatively, the repository included in the latest FreeRTOS release has also be updated to work with the latest SDK tools: http://www.freertos.org/RTOS-Xilinx-SDK-BSP.html
