dagustaf wrote on Tuesday, November 19, 2013:
Hi
I am trying to build a FreeRTOS BSP in EDK for Microblaze. It seems to be a path that is incorrect somewhere that tries to find “standalone_v3_01_a” but this directory is not present in the ISE 14.6 installation. Target is a Spartan6 on a custom board. I have already changed the "OPTION DEPENDS = (standalone_v3_07_a);"in “freertos_v2_1_0.mld” and the “set standalone_version standalone_v3_07_a” in “freertos_v2_1_0.tcl”. These were both originally st to “standalone_v3_01_a”.
The error I keep getting is:
make -k all
libgen -hw …/microblaze_1_hw_platform/system.xml
-lp C:/SDK_repository
-pe microblaze_0
-log libgen.log
system.mss
libgen
Xilinx EDK 14.6 Build EDK_P.68d
Copyright © 1995-2012 Xilinx, Inc. All rights reserved.
Command Line: libgen -hw …/microblaze_1_hw_platform/system.xml -lp
C:/SDK_repository -pe microblaze_0 -log libgen.log system.mss
Staging source files.
Running DRCs.
Running generate.
ERROR:EDK - freertos () - couldn’t open “…/standalone_v3_01_a/src/config.make”:
no such file or directory
ERROR:EDK:3416 - Error(s) while running TCL procedure generate().
make: *** [microblaze_0/lib/libxil.a] Error 2
make: Target `all’ not remade because of errors.
