gupta123 wrote on Friday, June 08, 2012:
Dear Rachid
Can you gide me I am using FTP_server.c &FTP_Server.h wants Port FTP Server on Atmel Microcontroller using FreeRTOS.I am Facing issue for compliation of netconn_api related for Atmel microntroller at91sam9xe-ek using SDCard for tranfer file using FTP.
/* ---------------- FreeRTOS includes ------------------- */
#include “FreeRTOS.h”
#include “task.h”
#include “semphr.h”
/* ---------------- lwIP includes ---------------------- */
#include “api.h”
/* ---------------- Project includes -------------------- */
#include “SD.h” /* SD Card Driver (SPI mode) */
#include “FAT.h”
#include “ftp_server.h”
#include “utilities.h”
#define FTP_USERNAME “user”
#define FTP_PASSWORD “Freescale123”
/*Handle SD card*/
static FATHandler *SD_FTP_Handle;
/*Read Buffer for App*/
static UINT8 *SDbuffer;
#define FTP_MUTEX_ENTER xSemaphoreTake((xSemaphoreHandle)SD_FTP_Handle->FAT_Mutex, portMAX_DELAY);
#define FTP_MUTEX_EXIT xSemaphoreGive((xSemaphoreHandle)SD_FTP_Handle->FAT_Mutex);
/*FSL:sprintf prototype*/
INT
sprintf(CHAR *, const CHAR *, … );
/********************Private Functions ***************************************/
* FTP Server Main Control Socket Parser: requests and responses
* Available requests: USER, PASS, PORT, QUIT
* @param connection descriptor
* @param buffer to hold FTP requests
* @return none
static uint8
vFTPConnection(struct netconn *connfd, uint8 *alloc_rq)
//uint8 temp_data;
uint8 correct_login = FALSE;
/*send FTP server first RESPONSE*/
//****RESPONSE OK CONNECTED
netconn_write(connfd,FTP_WELCOME_RESPONSE,str_len(FTP_WELCOME_RESPONSE),NULL);
do
/*if reception is OK: wait for REQUEST from client*/
netconn_rcv_req((void *)connfd, alloc_rq, NULL,NULL);
if(connfd->err != ERR_OK)
/*session closed by client*/
break;
/*authentication required*/
if( correct_login == TRUE)//already logged in
/*PORT request*/
if( strstr(alloc_rq,FTP_PORT_REQUEST) != NULL )
FTP_DataFlowControl(connfd,&alloc_rq);
/*DELETE request*/
else if( strstr(alloc_rq,FTP_DELE_REQUEST) != NULL )
if (FILE_DELETED == FAT_FileDelete(SD_FTP_Handle,SDbuffer,(uint8 *)strupr(&alloc_rq)) )
//****RESPONSE: OK
netconn_write(connfd,FTP_DELE_OK_RESPONSE,str_len(FTP_DELE_OK_RESPONSE),NULL);
//****RESPONSE: FAILED
netconn_write(connfd,FTP_WRITE_FAIL_RESPONSE,str_len(FTP_WRITE_FAIL_RESPONSE),NULL);
/*UNIMPLEMENTED request*/
if( !FTP_QUIT_OR_WRONG_REQUEST(connfd,alloc_rq) )
break;/*QUIT command*/
else//not logged in
if( strstr(alloc_rq,FTP_USER_REQUEST) != NULL )
/*authentication process: username matchs exactly?*/
if( !strncmp(&alloc_rq,FTP_USERNAME,str_len(FTP_USERNAME)) )
//*****RESPONSE USER OK
netconn_write(connfd,FTP_USER_RESPONSE,str_len(FTP_USER_RESPONSE),NULL);
netconn_rcv_req((void *)connfd, alloc_rq, NULL, NULL);
break;
if( strstr(alloc_rq,FTP_PASS_REQUEST) != NULL )
/*authentication process: password matchs exactly?*/
if( !strncmp(&alloc_rq,FTP_PASSWORD,str_len(FTP_PASSWORD)) )
//***RESPONSE: PASSWORD OK
netconn_write(connfd,FTP_PASS_OK_RESPONSE,str_len(FTP_PASS_OK_RESPONSE),NULL);
correct_login = TRUE;
//***RESPONSE: PASSWORD FAILED
netconn_write(connfd,FTP_PASS_FAIL_RESPONSE,str_len(FTP_PASS_FAIL_RESPONSE),NULL);
//***RESPONSE: EXPECTING PASS request
netconn_write(connfd,FTP_BAD_SEQUENCE_RESPONSE,str_len(FTP_BAD_SEQUENCE_RESPONSE),NULL);
//***RESPONSE USER FAILED
}while(1);
ftp_tcp_exit_low:
/*client closing the session*/
netconn_close(connfd);
netconn_delete(connfd);
/*close the session!!*/
return 1;/*default close value*/
* Closes or Leave session depending on client request
* @param buffer space
* @return 0 keep session, otherwise session needs to be closed
uint8
FTP_QUIT_OR_WRONG_REQUEST(struct netconn *connfd, uint8 *alloc_rq)
if( strstr(alloc_rq,FTP_QUIT_REQUEST) != NULL )
//****RESPONSE CLOSING SESSION: BYE
netconn_write(connfd,FTP_QUIT_RESPONSE,str_len(FTP_QUIT_RESPONSE),NULL);
return 1;/*close session*/
//****UNKNOWN REQUEST
netconn_write(connfd,FTP_UNKNOWN_RESPONSE,str_len(FTP_UNKNOWN_RESPONSE),NULL);
return 0;/*keep session*/
* Open data socket: ftp server connects to client.
* @param ip address to connect to
* @param tcp port to connect to
* @return connection descriptor, if NULL error, other OK.
struct netconn *
FTP_OpenDataPort(struct ip_addr *add, uint16 port)
/*START:open specific port requested by PORT*/
/* Create a new TCP connection handle. */
struct netconn *conn_data;
/*create data port*/
if( (conn_data = netconn_new(NETCONN_TCP)) == NULL )
return NULL;/*error*/
/*wait until it’s linked to server*/
if( netconn_connect(conn_data,add,port) != ERR_OK )
/*set timeout for this connection*/
//netconn_set_timeout((void *)conn_data,4000/*timeout*/);
/*END*/
return conn_data;
* Close data socket
* @return 0 if connection was closed
static uint8
FTP_CloseDataPort(struct netconn *conn_data)
/*delete TCP connection*/
netconn_close(conn_data);
netconn_delete(conn_data);
return 0;
* FTP Server Main Data Socket Parser: requests and responses
* Available requests: NLST, RTR, STOR
* @param string containing data socket port number and address
* @return none
static uint8
FTP_DataFlowControl(struct netconn *connfd, uint8 *alloc_rq)
/*netconn describing DATA flow path*/
/*FTP client IP address*/
T32_8 ip_address;
T16_8 ftp_port;
/*temporal pointers*/
CHAR *end;
/*temporal counter*/
CHAR i;
/*****START: get PORT information: parsing*/
//Get IP: four parts
for(i=0;i<sizeof(ip_address);i++)
end = (CHAR *)strchr((const CHAR *)alloc_rq,’,’);
ip_address.bytes = (uint8)strtoul(alloc_rq,(char **)&end,10);
alloc_rq = (uint8 *)end + 1;
//Get FTP Port:first part
ftp_port.u8 = (uint8)strtoul(alloc_rq,(char **)&end,10);
//Get FTP Port:second part
end = (CHAR *)strchr((const CHAR *)alloc_rq,’\r’);
/*****END**********************************/
//*****RESPONSE: OPEN PORT
netconn_write(connfd,FTP_PORT_OK_RESPONSE,str_len(FTP_PORT_OK_RESPONSE),NULL);
/*if reception is OK: wait for REQUEST from client from CONTROL port*/
return 1;/*FAIL*/
/*NLST*/
if( strstr(alloc_rq,FTP_NLST_REQUEST) != NULL )
if( (conn_data = FTP_OpenDataPort((struct ip_addr *)&(ip_address.lword),ftp_port.u16)) != NULL )
//****Response Sending
netconn_write(connfd,FTP_NLST_OK_RESPONSE,str_len(FTP_NLST_OK_RESPONSE),NULL);
//Send the file list
FTP_Read_List_Of_Files(conn_data);
//Start Closing Data Stream
FTP_CloseDataPort(conn_data);
//****RESPONSE: OK
netconn_write(connfd,FTP_TRANSFER_OK_RESPONSE,str_len(FTP_TRANSFER_OK_RESPONSE),NULL);
//****RESPONSE PORT cant be opened!!
netconn_write(connfd,FTP_DATA_PORT_FAILED,str_len(FTP_DATA_PORT_FAILED),NULL);
return 1;/*FAIL*/
/*READ*/
else if( strstr(alloc_rq,FTP_RETR_REQUEST) != NULL )
if( !FTP_Read_Is_Possible(&alloc_rq) )
netconn_write(connfd,FTP_RETR_OK_RESPONSE,str_len(FTP_RETR_OK_RESPONSE),NULL);
//send info
FTP_Read_File(conn_data);
//****RESPONSE: OK
return 1;
//****RESPONSE: DUPLICATION FILE NAME
/*WRITE*/
else if( strstr(alloc_rq,FTP_STOR_REQUEST) != NULL )
if( !FTP_Does_File_Exist(&alloc_rq) )
//****RESPONSE: FILE ALREADY EXISTS
netconn_write(connfd,FTP_STOR_OK_RESPONSE,str_len(FTP_STOR_OK_RESPONSE),NULL);
/*filename to write*/
FTP_Write_File(conn_data,&alloc_rq);
//Start Closing Data Stream: client closes tcp session: against protocol!!
//****RESPONSE: OK
return 1;/*FAIL*/
/*UNKNOWN OR NOT IMPLEMENTED*/
//****Response: unknown request
netconn_write(connfd,FTP_CMD_NOT_IMP_RESPONSE,str_len(FTP_CMD_NOT_IMP_RESPONSE),NULL);
return 0;/*OK*/
* Look if a file already exist with the name
* No case sensitive
* @param file name to look for on FAT
* @return 0 if file was found, otherwise not
uint8
FTP_Does_File_Exist(uint8 *data)
UINT8 result = 1;
UINT8 i=0;
/*convert to upper case:???*/
strupr(data);
/*FSL: SD Mutex Enter*/
FTP_MUTEX_ENTER
if(!FAT_LS(SD_FTP_Handle,SDbuffer,(void*)data,FTP_CompareFile))
result = 0;/*file found*/
/*SD Mutex Exit*/
FTP_MUTEX_EXIT
return result;/*File not found*/
* Callback to send files name to ethernet
* @param descriptor to use for sending
* @param filename string
* @return always 1
UINT8
FTP_SD_send(void* var,UINT8 *fileName)
struct netconn *connfd = (struct netconn *)var;
/*append “\r\n”*/
strcat( fileName, STRING_END );
/*send files name*/
netconn_write(connfd,fileName,strlen(fileName),NETCONN_COPY);
return 1;
* Callback to check if file exists
* @param data to compare
* @return 0 if file found, otherwise zero
UINT8
FTP_CompareFile(void* var,UINT8 *fileName)
UINT8 *string = (UINT8 *)var;
if( !strcmp(string,(const uint8 *)SDbuffer) )
return 0;/*File Found*/
return 1;/*File not found*/
* Returns thru connection descriptor all files names in FAT
* @param connection descriptor to send files’ names
* @return 0 if read was OK, otherwise not
uint8
FTP_Read_List_Of_Files(struct netconn *connfd)
UINT8 u8BlockCounter=0;
UINT8 u8BlockOffset=0;
//TODO: what happens if no files at all?
FTP_MUTEX_ENTER
/*dont care what it returns*/
(void)FAT_LS(SD_FTP_Handle,SDbuffer,connfd,FTP_SD_send);
/*SD Mutex Exit*/
FTP_MUTEX_EXIT
return 0;/*OK*/
* Check if filename exists in FAT system for reading
* @param file name to check
* @return 0 if read is possible, otherwise not
uint8
FTP_Read_Is_Possible(uint8 *data)
UINT8 result = 1;
FTP_MUTEX_ENTER;
/*Look for file on SD card: uppercase is needed*/
if( !FAT_FileOpen(SD_FTP_Handle,SDbuffer,(uint8 *)strupr(data),READ) )
result = 0;/*OK*/
/*SD Mutex Exit*/
FTP_MUTEX_EXIT
return result;/*Fail*/
* Gets a file from FAT and send it to a connection descriptor
* Call FTP_Read_Is_Possible(…)
* @param connection descriptor to write data read data
uint8
FTP_Read_File(struct netconn *connfd)
UINT16 u16Length;
/*first call: FTP_Read_Is_Possible(…)*/
FTP_MUTEX_ENTER
/*File exists so */
while( (u16Length=FAT_FileRead(SD_FTP_Handle,SDbuffer)) == BLOCK_SIZE )
/*start sending SD BLOCKs*/
netconn_write(connfd,SDbuffer,BLOCK_SIZE,NETCONN_COPY);
if(u16Length)
/*start sending remaining SD BLOCK*/
netconn_write(connfd,SDbuffer,u16Length,NETCONN_COPY);
/*SD Mutex Exit*/
FTP_MUTEX_EXIT
return 0;/*OK*/
* Puts a file from a connection descriptor and send it to FAT
* First check if file do not exist to avoid duplication of files in FAT
* @param connection descriptor to use read data
* @param file name to write.
uint8
FTP_Write_File(struct netconn *connfd, uint8 *data)
UINT16 length;
/*receiver buffer*/
struct netbuf *inbuf;
struct pbuf *q;
/*Prior:string already doesnt exist on FAT*/
FTP_MUTEX_ENTER
/*Write File: remaining bits: doesn’t check for file names’ duplication*/
if( FAT_FileOpen(SD_FTP_Handle,SDbuffer,(uint8 *)strupr(data),CREATE) == FILE_CREATE_OK )
do
/*stay here until session is: closed, received or out of memory*/
length = netconn_rcv_req((void *)connfd, NULL, (void **)&inbuf, NETCONN_RCV_NETBUFFER);
if( connfd->err == ERR_OK )
/*start segment index: copy all the network buffer segments*/
q = inbuf->ptr;
do
/*write as many bytes as needed*/
FAT_FileWrite(SD_FTP_Handle,SDbuffer,q->payload,q->len);
while( ( q = q->next ) != NULL );
/*free pbuf memory*/
netbuf_delete(inbuf);
/*session closed, out of memory, timeout: leave loop*/
break;
}while(1);
/*close file*/
FAT_FileClose(SD_FTP_Handle,SDbuffer);
/*SD Mutex Exit*/
FTP_MUTEX_EXIT
return length;/*Error*/
* Start an embedded FTP server Task: 1 client and 1 file per transfer
* @param paremeter pointer to use with task
* @return none
void
vBasicFTPServer( void *pvParameters )
/*Connection descriptors for FTP control port*/
struct netconn *conn, *connection;
uint8 *alloc_rq;
UINT8 i = FTP_CLOSED;/*keep session information*/
/* Parameters are not used - suppress compiler error. */
( void )pvParameters;
/*Apps buffer*/
if( ((SDbuffer=(uint8 *)mem_malloc( BLOCK_SIZE )) == NULL) ||
((alloc_rq=(uint8 *)mem_malloc( FTP_REQUEST_SPACE )) == NULL) )
mem_free(SDbuffer);
mem_free(alloc_rq);
/*Task no longer needed, delete it!*/
vTaskDelete( NULL );
/* SD Card Initialization */
if( (SD_FTP_Handle = FAT_INIT(SDbuffer)) == NULL )
/*delete requested memory*/
mem_free(SDbuffer);
mem_free(alloc_rq);
/*error*/
FAT_Close();
/**********************FSL: socket start-up*******************************/
** conn = netconn_new(NETCONN_TCP);**
/* Bind the connection to port 21 on any local IP address. */
netconn_bind(conn, NULL, FTP_TCP_CONTROL_PORT);
/* Put the connection into LISTEN state. */
netconn_listen(conn);
netconn_set_timeout((void *)conn,0/*timeout*/);
for(;;)/*infinite loop*/
if( i == FTP_CLOSED )/*FTP_CLOSE*/
if( (connection = netconn_accept(conn)) != NULL )
i = FTP_OPEN;
netconn_set_timeout((void *)connection,0/*timeout*/);
else/*FTP_OPEN*/
/* Service connection */
if( vFTPConnection( connection, alloc_rq ) )
i = FTP_CLOSED;
/*never get here!*/
return;
