gupta123 wrote on Friday, June 08, 2012:
I want Port FTP Server code of FreeScales on Atmel Microcontroller.code file are this.The issue is compliation they are used netconn API .is any project in Atmel that suport netconn API on Atmel Device using LWIP TCP/IP stack.
/* ---------------- FreeRTOS includes ------------------- */
#include “FreeRTOS.h”
#include “task.h”
#include “semphr.h”
/* ---------------- lwIP includes ---------------------- */
#include “api.h”
/* ---------------- Project includes -------------------- */
#include “SD.h” /* SD Card Driver (SPI mode) */
#include “FAT.h”
#include “ftp_server.h”
#include “utilities.h”
#define FTP_USERNAME “user”
#define FTP_PASSWORD “Freescale123”
/*Handle SD card*/
static FATHandler *SD_FTP_Handle;
/*Read Buffer for App*/
static UINT8 *SDbuffer;
#define FTP_MUTEX_ENTER xSemaphoreTake((xSemaphoreHandle)SD_FTP_Handle->FAT_Mutex, portMAX_DELAY);
#define FTP_MUTEX_EXIT xSemaphoreGive((xSemaphoreHandle)SD_FTP_Handle->FAT_Mutex);
/*FSL:sprintf prototype*/
INT
sprintf(CHAR *, const CHAR *, … );
/********************Private Functions ***************************************/
* FTP Server Main Control Socket Parser: requests and responses
* Available requests: USER, PASS, PORT, QUIT
* @param connection descriptor
* @param buffer to hold FTP requests
* @return none
static uint8
vFTPConnection(struct netconn *connfd, uint8 *alloc_rq)
//uint8 temp_data;
uint8 correct_login = FALSE;
/*send FTP server first RESPONSE*/
//****RESPONSE OK CONNECTED
netconn_write(connfd,FTP_WELCOME_RESPONSE,str_len(FTP_WELCOME_RESPONSE),NULL);
do
/*if reception is OK: wait for REQUEST from client*/
netconn_rcv_req((void *)connfd, alloc_rq, NULL,NULL);
if(connfd->err != ERR_OK)
/*session closed by client*/
break;
/*authentication required*/
if( correct_login == TRUE)//already logged in
/*PORT request*/
if( strstr(alloc_rq,FTP_PORT_REQUEST) != NULL )
FTP_DataFlowControl(connfd,&alloc_rq);
/*DELETE request*/
else if( strstr(alloc_rq,FTP_DELE_REQUEST) != NULL )
if (FILE_DELETED == FAT_FileDelete(SD_FTP_Handle,SDbuffer,(uint8 *)strupr(&alloc_rq)) )
//****RESPONSE: OK
netconn_write(connfd,FTP_DELE_OK_RESPONSE,str_len(FTP_DELE_OK_RESPONSE),NULL);
//****RESPONSE: FAILED
netconn_write(connfd,FTP_WRITE_FAIL_RESPONSE,str_len(FTP_WRITE_FAIL_RESPONSE),NULL);
/*UNIMPLEMENTED request*/
if( !FTP_QUIT_OR_WRONG_REQUEST(connfd,alloc_rq) )
break;/*QUIT command*/
else//not logged in
if( strstr(alloc_rq,FTP_USER_REQUEST) != NULL )
/*authentication process: username matchs exactly?*/
if( !strncmp(&alloc_rq,FTP_USERNAME,str_len(FTP_USERNAME)) )
//*****RESPONSE USER OK
netconn_write(connfd,FTP_USER_RESPONSE,str_len(FTP_USER_RESPONSE),NULL);
netconn_rcv_req((void *)connfd, alloc_rq, NULL, NULL);
break;
if( strstr(alloc_rq,FTP_PASS_REQUEST) != NULL )
/*authentication process: password matchs exactly?*/
if( !strncmp(&alloc_rq,FTP_PASSWORD,str_len(FTP_PASSWORD)) )
//***RESPONSE: PASSWORD OK
netconn_write(connfd,FTP_PASS_OK_RESPONSE,str_len(FTP_PASS_OK_RESPONSE),NULL);
correct_login = TRUE;
//***RESPONSE: PASSWORD FAILED
netconn_write(connfd,FTP_PASS_FAIL_RESPONSE,str_len(FTP_PASS_FAIL_RESPONSE),NULL);
//***RESPONSE: EXPECTING PASS request
netconn_write(connfd,FTP_BAD_SEQUENCE_RESPONSE,str_len(FTP_BAD_SEQUENCE_RESPONSE),NULL);
//***RESPONSE USER FAILED
}while(1);
ftp_tcp_exit_low:
/*client closing the session*/
netconn_close(connfd);
netconn_delete(connfd);
/*close the session!!*/
return 1;/*default close value*/
* Closes or Leave session depending on client request
* @param buffer space
* @return 0 keep session, otherwise session needs to be closed
uint8
FTP_QUIT_OR_WRONG_REQUEST(struct netconn *connfd, uint8 *alloc_rq)
if( strstr(alloc_rq,FTP_QUIT_REQUEST) != NULL )
//****RESPONSE CLOSING SESSION: BYE
netconn_write(connfd,FTP_QUIT_RESPONSE,str_len(FTP_QUIT_RESPONSE),NULL);
return 1;/*close session*/
//****UNKNOWN REQUEST
netconn_write(connfd,FTP_UNKNOWN_RESPONSE,str_len(FTP_UNKNOWN_RESPONSE),NULL);
return 0;/*keep session*/
* Open data socket: ftp server connects to client.
* @param ip address to connect to
* @param tcp port to connect to
* @return connection descriptor, if NULL error, other OK.
struct netconn *
FTP_OpenDataPort(struct ip_addr *add, uint16 port)
/*START:open specific port requested by PORT*/
/* Create a new TCP connection handle. */
struct netconn *conn_data;
/*create data port*/
if( (conn_data = netconn_new(NETCONN_TCP)) == NULL )
return NULL;/*error*/
/*wait until it’s linked to server*/
if( netconn_connect(conn_data,add,port) != ERR_OK )
/*set timeout for this connection*/
//netconn_set_timeout((void *)conn_data,4000/*timeout*/);
/*END*/
return conn_data;
* Close data socket
* @return 0 if connection was closed
static uint8
FTP_CloseDataPort(struct netconn *conn_data)
/*delete TCP connection*/
netconn_close(conn_data);
netconn_delete(conn_data);
return 0;
* FTP Server Main Data Socket Parser: requests and responses
* Available requests: NLST, RTR, STOR
* @param string containing data socket port number and address
* @return none
static uint8
FTP_DataFlowControl(struct netconn *connfd, uint8 *alloc_rq)
/*netconn describing DATA flow path*/
/*FTP client IP address*/
T32_8 ip_address;
T16_8 ftp_port;
/*temporal pointers*/
CHAR *end;
/*temporal counter*/
CHAR i;
/*****START: get PORT information: parsing*/
//Get IP: four parts
for(i=0;i<sizeof(ip_address);i++)
end = (CHAR *)strchr((const CHAR *)alloc_rq,’,’);
ip_address.bytes_ = (uint8)strtoul(alloc_rq,(char **)&end,10);
alloc_rq = (uint8 *)end + 1;
//Get FTP Port:first part
ftp_port.u8 = (uint8)strtoul(alloc_rq,(char **)&end,10);
//Get FTP Port:second part
end = (CHAR *)strchr((const CHAR *)alloc_rq,’\r’);
/*****END**********************************/
//*****RESPONSE: OPEN PORT
netconn_write(connfd,FTP_PORT_OK_RESPONSE,str_len(FTP_PORT_OK_RESPONSE),NULL);
/*if reception is OK: wait for REQUEST from client from CONTROL port*/
return 1;/*FAIL*/
/*NLST*/
if( strstr(alloc_rq,FTP_NLST_REQUEST) != NULL )
if( (conn_data = FTP_OpenDataPort((struct ip_addr *)&(ip_address.lword),ftp_port.u16)) != NULL )
//****Response Sending
netconn_write(connfd,FTP_NLST_OK_RESPONSE,str_len(FTP_NLST_OK_RESPONSE),NULL);
//Send the file list
FTP_Read_List_Of_Files(conn_data);
//Start Closing Data Stream
FTP_CloseDataPort(conn_data);
//****RESPONSE: OK
netconn_write(connfd,FTP_TRANSFER_OK_RESPONSE,str_len(FTP_TRANSFER_OK_RESPONSE),NULL);
//****RESPONSE PORT cant be opened!!
netconn_write(connfd,FTP_DATA_PORT_FAILED,str_len(FTP_DATA_PORT_FAILED),NULL);
return 1;/*FAIL*/
/*READ*/
else if( strstr(alloc_rq,FTP_RETR_REQUEST) != NULL )
if( !FTP_Read_Is_Possible(&alloc_rq) )
netconn_write(connfd,FTP_RETR_OK_RESPONSE,str_len(FTP_RETR_OK_RESPONSE),NULL);
//send info
FTP_Read_File(conn_data);
//****RESPONSE: OK
return 1;
//****RESPONSE: DUPLICATION FILE NAME
/*WRITE*/
else if( strstr(alloc_rq,FTP_STOR_REQUEST) != NULL )
if( !FTP_Does_File_Exist(&alloc_rq) )
//****RESPONSE: FILE ALREADY EXISTS
netconn_write(connfd,FTP_STOR_OK_RESPONSE,str_len(FTP_STOR_OK_RESPONSE),NULL);
/*filename to write*/
FTP_Write_File(conn_data,&alloc_rq);
//Start Closing Data Stream: client closes tcp session: against protocol!!
//****RESPONSE: OK
return 1;/*FAIL*/
/*UNKNOWN OR NOT IMPLEMENTED*/
//****Response: unknown request
netconn_write(connfd,FTP_CMD_NOT_IMP_RESPONSE,str_len(FTP_CMD_NOT_IMP_RESPONSE),NULL);
return 0;/*OK*/
* Look if a file already exist with the name
* No case sensitive
* @param file name to look for on FAT
* @return 0 if file was found, otherwise not
uint8
FTP_Does_File_Exist(uint8 *data)
UINT8 result = 1;
UINT8 i=0;
/*convert to upper case:???*/
strupr(data);
/*FSL: SD Mutex Enter*/
FTP_MUTEX_ENTER
if(!FAT_LS(SD_FTP_Handle,SDbuffer,(void*)data,FTP_CompareFile))
result = 0;/*file found*/
/*SD Mutex Exit*/
FTP_MUTEX_EXIT
return result;/*File not found*/
* Callback to send files name to ethernet
* @param descriptor to use for sending
* @param filename string
* @return always 1
UINT8
FTP_SD_send(void* var,UINT8 *fileName)
struct netconn *connfd = (struct netconn *)var;
/*append “\r\n”*/
strcat( fileName, STRING_END );
/*send files name*/
netconn_write(connfd,fileName,strlen(fileName),NETCONN_COPY);
return 1;
* Callback to check if file exists
* @param data to compare
* @return 0 if file found, otherwise zero
UINT8
FTP_CompareFile(void* var,UINT8 *fileName)
UINT8 *string = (UINT8 *)var;
if( !strcmp(string,(const uint8 *)SDbuffer) )
return 0;/*File Found*/
return 1;/*File not found*/
* Returns thru connection descriptor all files names in FAT
* @param connection descriptor to send files’ names
* @return 0 if read was OK, otherwise not
uint8
FTP_Read_List_Of_Files(struct netconn *connfd)
UINT8 u8BlockCounter=0;
UINT8 u8BlockOffset=0;
//TODO: what happens if no files at all?
FTP_MUTEX_ENTER
/*dont care what it returns*/
(void)FAT_LS(SD_FTP_Handle,SDbuffer,connfd,FTP_SD_send);
/*SD Mutex Exit*/
FTP_MUTEX_EXIT
return 0;/*OK*/
* Check if filename exists in FAT system for reading
* @param file name to check
* @return 0 if read is possible, otherwise not
uint8
FTP_Read_Is_Possible(uint8 *data)
UINT8 result = 1;
FTP_MUTEX_ENTER;
/*Look for file on SD card: uppercase is needed*/
if( !FAT_FileOpen(SD_FTP_Handle,SDbuffer,(uint8 *)strupr(data),READ) )
result = 0;/*OK*/
/*SD Mutex Exit*/
FTP_MUTEX_EXIT
return result;/*Fail*/
* Gets a file from FAT and send it to a connection descriptor
* Call FTP_Read_Is_Possible(…)
* @param connection descriptor to write data read data
uint8
FTP_Read_File(struct netconn *connfd)
UINT16 u16Length;
/*first call: FTP_Read_Is_Possible(…)*/
FTP_MUTEX_ENTER
/*File exists so */
while( (u16Length=FAT_FileRead(SD_FTP_Handle,SDbuffer)) == BLOCK_SIZE )
/*start sending SD BLOCKs*/
netconn_write(connfd,SDbuffer,BLOCK_SIZE,NETCONN_COPY);
if(u16Length)
/*start sending remaining SD BLOCK*/
netconn_write(connfd,SDbuffer,u16Length,NETCONN_COPY);
/*SD Mutex Exit*/
FTP_MUTEX_EXIT
return 0;/*OK*/
* Puts a file from a connection descriptor and send it to FAT
* First check if file do not exist to avoid duplication of files in FAT
* @param connection descriptor to use read data
* @param file name to write.
uint8
FTP_Write_File(struct netconn *connfd, uint8 *data)
UINT16 length;
/*receiver buffer*/
struct netbuf *inbuf;
struct pbuf *q;
/*Prior:string already doesnt exist on FAT*/
FTP_MUTEX_ENTER
/*Write File: remaining bits: doesn’t check for file names’ duplication*/
if( FAT_FileOpen(SD_FTP_Handle,SDbuffer,(uint8 *)strupr(data),CREATE) == FILE_CREATE_OK )
do
/*stay here until session is: closed, received or out of memory*/
length = netconn_rcv_req((void *)connfd, NULL, (void **)&inbuf, NETCONN_RCV_NETBUFFER);
if( connfd->err == ERR_OK )
/*start segment index: copy all the network buffer segments*/
q = inbuf->ptr;
do
/*write as many bytes as needed*/
FAT_FileWrite(SD_FTP_Handle,SDbuffer,q->payload,q->len);
while( ( q = q->next ) != NULL );
/*free pbuf memory*/
netbuf_delete(inbuf);
/*session closed, out of memory, timeout: leave loop*/
break;
}while(1);
/*close file*/
FAT_FileClose(SD_FTP_Handle,SDbuffer);
/*SD Mutex Exit*/
FTP_MUTEX_EXIT
return length;/*Error*/
* Start an embedded FTP server Task: 1 client and 1 file per transfer
* @param paremeter pointer to use with task
* @return none
void
vBasicFTPServer( void *pvParameters )
/*Connection descriptors for FTP control port*/
struct netconn *conn, *connection;
uint8 *alloc_rq;
UINT8 i = FTP_CLOSED;/*keep session information*/
/* Parameters are not used - suppress compiler error. */
( void )pvParameters;
/*Apps buffer*/
if( ((SDbuffer=(uint8 *)mem_malloc( BLOCK_SIZE )) == NULL) ||
((alloc_rq=(uint8 *)mem_malloc( FTP_REQUEST_SPACE )) == NULL) )
mem_free(SDbuffer);
mem_free(alloc_rq);
/*Task no longer needed, delete it!*/
vTaskDelete( NULL );
/* SD Card Initialization */
if( (SD_FTP_Handle = FAT_INIT(SDbuffer)) == NULL )
/*delete requested memory*/
mem_free(SDbuffer);
mem_free(alloc_rq);
/*error*/
FAT_Close();
/**********************FSL: socket start-up*******************************/
conn = netconn_new(NETCONN_TCP);
/* Bind the connection to port 21 on any local IP address. */
netconn_bind(conn, NULL, FTP_TCP_CONTROL_PORT);
/* Put the connection into LISTEN state. */
netconn_listen(conn);
netconn_set_timeout((void *)conn,0/*timeout*/);
for(;;)/*infinite loop*/
if( i == FTP_CLOSED )/*FTP_CLOSE*/
if( (connection = netconn_accept(conn)) != NULL )
i = FTP_OPEN;
netconn_set_timeout((void *)connection,0/*timeout*/);
else/*FTP_OPEN*/
/* Service connection */
if( vFTPConnection( connection, alloc_rq ) )
i = FTP_CLOSED;
/*never get here!*/
return;
_
