balajisubrcyp wrote on Thursday, June 14, 2018:
Hi All,
I am spawning a thread using below function in FreeRTOS v9.0.0
result = xTaskCreate( (TaskFunction_t)entry_function, name, (unsigned short)(stack_size / sizeof( portSTACK_TYPE )), (void*)arg, (unsigned portBASE_TYPE) priority, thread );
return ( result == (signed portBASE_TYPE) pdPASS ) ? WWD_SUCCESS : WWD_THREAD_CREATE_FAILED;
This Task is created. In this task I run an Iperf Server thread which receive packets from a remote endpoint with data rate of 60Mbps. After about 400 seconds, the Iperf Thread quits and in the calling thread
vTaskDelete(NULL);
is called before exiting the function. this functions calls to remove the pxTCB from the list and here it hangs..
(UBaseType_t uxListRemove( ListItem_t * const pxItemToRemove )
/* The list item knows which list it is in. Obtain the list from the list
item. */
List_t * const pxList = ( List_t * ) pxItemToRemove->pvContainer;
pxItemToRemove->pxNext->pxPrevious = pxItemToRemove->pxPrevious;
pxItemToRemove->pxPrevious->pxNext = pxItemToRemove->pxNext;
Is this know problem with FreeRTOS the vTaskDelete(NULL) to remove resources fo r current thread causes an system hang…
Thanks
Balaji.
