rseedle wrote on Friday, July 29, 2016:
I have compiled the UDP/IP demo. I have the debugger running the command line. And it obtains an
IP address on my Windows PC. When I try to use the YAT it displays a messege:
Unable to start terminal!
System error messege:
Only one usage of each socket address (protocol/network address/port)
is normally permitted.
YAT hint:
Make sure the selected socket is not already in use.
How can I go about checking if this network address/port is in use already ?
