This task is triggered every two seconds instead of one second (as intended by vTaskDelay(1000)). I did not make any changes to the code, configCPU_CLOCK_HZ is set as 1000.
Can anyone verify if this is true or point out the direction which I should be looking to check for sysTick rate?
You code looks Ok.
So what you observe is a LED that is on for 2 seconds, and then off for 2 seconds?
I would check the clocks of the SAME70 at start-up: is it assuming a correct speed of the X-tal? Is the processor running at the expected speed?
The value of configCPU_CLOCK_HZ looks suspicious. Are you using the
SysTick clock to generate tick interrupts? If so I would expect it to
be in the MHz range, not 1Khz.
configCPU_CLOCK_HZ is the clock rate of the CPU, up to 300 MHz for SAM E70 configSYSTICK_CLOCK_HZ is the clock rate that feeds the systick, possibly the same as configCPU_CLOCK_HZ configTICK_RATE_HZ is the desired FreeRTOS tick rate, which you will put to 1000
For SAME70, the systick is initialised in portable/gcc/ARM_CM7/r0p1/port.c in the function vPortSetupTimerInterrupt() Could you check these defines and find-out the logic?
I think that:
#define configCPU_CLOCK_HZ ( SystemCoreClock )
could you check or print the actual value of SystemCoreClock?
@RichardBarry my mistake, i meant configTICK_RATE_HZ = 1000.
@Hein Tibosch yes that is correct, the LED is on for 2 seconds then off for 2 seconds.
i ran a demo project without FreeRTOS (same board config settings) , no issue with tick timing. LED swtiched on for 1 second and off for 1 second.
same70_xplained.h
/#define BOARD_MCK 300000000UL
freeRTOSconfig.h
checking on the settings, i noticed that:
/#define configCPU_CLOCK_HZ (BOARD_MCK << 1UL)
seems like freeRTOSconfig.h defines the configCPU_CLOCK_HZ, in this case to 600MHz.
changing this value to 300MHz resulted in the correct tick rate.
I am not sure what is the reason for the left shift bit, can i assumed that it will be alright for me to just #define configCPU_CLOCK_HZ BOARD_MCK ?
just for fun (thinking why the rate will be slower at 600MHz), I tested it with 150MHz and it resulted in a faster tick rate (0.5s). Would you happen to have any explanation as to why lowering the CPU clock rate resulted in a faster tick rate?
