Until now I used FreeRTOS using “lwip 1.4.1”, but I encountered
problems. I’m going to try FreeRTOS+TCP but for now there are no
drivers for Xilinx “ethernetlite”.
You have already sketched a driver to start ?
Reading code of FreeRTOS+TCP I have not found a way to restart the
network interface with a new MAC address and IP configuration.
While we do have a port for the Zynq, you are right in that it is not using the Ethernet Lite IP. I’m guessing that, if you are using Eithernet Lite, then you are also using the Microblaze. Xilinx provide drivers themselves, and a description of how these drivers can be stitched into the FreeRTOS+TCP porting layer is provided on the following link: http://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_TCP/FreeRTOS_TCP_Porting.html
