I’m using a FreeRTOS+TCP UDP socket. According to the documentation of FreeRTOS_recvfrom the default timeout is portMAX_DELAY which should block indefinitely. What I’m actually seeing is after receiving a bunch of packets, then idling for some time it returns -pdFREERTOS_ERRNO_EWOULDBLOCK. I haven’t set any socket options so I find this behavior puzzling and worry there’s something more sinister at play. Does anyone have insight?
The documentation says the default value for ipconfigSOCK_DEFAULT_RECEIVE_BLOCK_TIME is portMAX_DELAY as you mentioned. This value is applied by FreeRTOSIPConfigDefaults.h here if ipconfigSOCK_DEFAULT_RECEIVE_BLOCK_TIME is not defined in your configuration. Can you verify that ipconfigSOCK_DEFAULT_RECEIVE_BLOCK_TIME is not configured in your project?
