laughlinmbari wrote on Monday, September 09, 2019:
I’ve stumbled across the following behavior where I was able to hang FreeRTOS_send (it would not return, and the thread responsible for doing IP comms would hang as a result). The undesireable behavior appers to be easily mitigated by setting an appropriate FREERTOS_SO_RCVTIMEO (which hadn’t been set in my system I was working on). Digging into the source, it seems to me that there is logic within FreeRTOS_send is intended to catch a situation like this, which is why I’m posting this.
Setup: My FreeRTOS MCU is hosting a few listening sockets, and upon receipt of a connection, creats a child socket which it hands off to a seperate comms application. The seperate comms application parses incoming UI commands, and if the appropriate command is received sends back the appropriate data.
The listening sockets do not have a FREERTOS_SO_SNDTIMEO set (so their children sockets don’t inherit one).
It appears to be sensitive to timing, but I can reproduce it ~1/10 with the following script on my desktop:
import socket
import time
def sleep_ms(sec):
time.sleep(sec/1000.0)
HOST = "10.0.0.2"
PORT = 10003
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
print("opening socket...\n")
try:
s.connect((HOST, PORT))
data = s.recv(1024)
time.sleep(1)
except OSError as msg:
print(msg)
cmd = b'b_req\r\n'
print("sending command: {} and exiting".format(cmd.decode('ascii')))
s.sendall(cmd)
sleep_ms(1)
exit()
The basic flow of the comms app is as follows:
while(1){
sres = FreeRTOS_select(task->active_fds, xSelectTimeout);
if (sres < 0) {
panic ("select");
} else if (sres == 0) {
// nothing happening on any socket
continue;
/* cycle through configured apps and check for incoming requests */
for (i = 0; i < task->appnum; i++) {
app = task->apps[i];
/* check for requests on established connections */
for (j = 0; j < MAX_APP_CLIENTS; j++) {
if (!app->clientsocks[j] || !FreeRTOS_FD_ISSET(app->clientsocks[j],
task->active_fds))
continue;
/* data arriving on an already-connected socket. */
res = FreeRTOS_recv(app->clientsocks[j], app->tcp_buffer,
TCP_BUFSIZE, 0);
if (res <= 0 || app->request_handler(app, j, res) < 0) {
/* Read error (-1) or EOF (0) */
utils_socket_close(app->clientsocks[j]);
FreeRTOS_FD_CLR(app->clientsocks[j], task->active_fds, eSELECT_READ | eSELECT_EXCEPT);
app->clientsocks[j] = 0;
continue;
if (app->app_type != SERIAL_APP) taskYIELD();
/* check for incoming new connections on master sock */
if (!app->master_sock || !FreeRTOS_FD_ISSET(app->master_sock, task->active_fds))
continue;
len = sizeof (client);
newsock = FreeRTOS_accept(app->master_sock, &client, &len);
if (newsock < 0) {
perror ("accept");
panic ("EXIT_FAILURE");
if (!app->clientsocks[j]) {
FreeRTOS_FD_SET(newsock, task->active_fds, eSELECT_READ | eSELECT_EXCEPT);
app->clientsocks[j] = newsock;
break;
if (j >= MAX_APP_CLIENTS) {
tcp_srv_respond_term(newsock,
"\r\nToo many active connections, closing!\r\n\n");
utils_socket_close(newsock);
continue;
if (xPortGetFreeHeapSize() < TCP_MIN_FREE_HEAP) {
"\r\nRunning low on memory, closing!\r\nConsider closing unused connections.\r\n\n");
continue;
if (app->app_type != SERIAL_APP) {
sprintf(response, "\xff\xfd\x22\xff\xfa\x22\x01\x01\xff\xf0\r\n\nConnected to %s \r\n%s> ",
app->name, app->name);
tcp_srv_respond_term(newsock, response);
and the basic structure of the UI respond task is
parse_cmd(APP_CFG *app, int sockidx, int len)
Socket_t sock = app->clientsocks[sockidx];
char *srv_inbuf = app->tcp_buffer;
int battery;
float fval1, fval2, fval3;
uint16_t *voltages;
uint8_t types[2];
srv_inbuf[len] = 0;
//some error checking and sanitizing stuff here
else if (!strncmp(srv_inbuf,"b_req", 5)) {
char *strPtr = str_data;
//... query some ADCs and GPIO, copy some structs, and then send back
// data with calls to tcp_srv_respond() see below.
the FreeRTOS_send wrapper for reference:
int tcp_srv_respond(Socket_t sock, char *bufp, int bytestosend)
int bytessent;
while (bytestosend) {
bytessent = FreeRTOS_send(sock, bufp, bytestosend, 0);
if (bytessent < 0) {
return (-1);
} else if (bytessent == 0) {
return (0);
} else if (bytessent < bytestosend) {
/* Only part of the data was written */
bufp += bytessent;
bytestosend -= bytessent;
taskYIELD(); /* Let other tasks run before we try again */
continue;
} else {
break; /* All bytes sent */
return (0);
To reiterate, the problem can be resolved by introducing a SEND timeout, so my particular issue has been resolved, but I’ve posted here because my reading of the FreeRTOS_send leads me to beleive this may be an unintended behavior.
Cheers.
