FreeRTOS+TCP STM32H743 Ping/Broadcasts triggers RX Buffer Starvation
Hi!
I encounter a problem that seem to be the exact same as the one encountered by @pgreenland in his FreeRTOS+TCP STM32H7 UDP Ping Lockup RX Buffer Starvation or at least a very similar one. The problem occurs even when no application is actually using TCP or UDP, I’m just pinging the device to test if the ethernet stack is actually running. The system is working a few seconds then the error occurs 5 times and the device stop responding to pings. Changing the value of ipconfigNUM_NETWORK_BUFFER_DESCRIPTORS seem to make no difference, or it only make it crash a little more quickly with a low number like 5.
I’m using:
  • /FreeRTOS-Plus/FreeRTOS-Plus-TCP/source/portable/BufferManagement/BufferAllocation_2.c
  • /FreeRTOS-Plus/FreeRTOS-Plus-TCP/source/portable/NetworkInterface/STM32/NetworkInterface.c implementation (the new one, not a legacy, I deleted the legacy one in my project to be sure)
  • ${FREERTOS_KERNEL_PATH}/portable/MemMang/heap_4.c
I have tried using that FreeRTOSIPConfig.h (see next message) and PG’s one but that didn’t made any difference.
I’ve had ipconfigTCP_IP_SANITY not defined, so I’ll try using it for the next tests to come. I however received messages from FreeRTOS_debug_printf() (like “HAL_ETH_RxAllocateCallback: failed\n”) already so I don’t know if it’ll reveal something else.
I haveipconfigZERO_COPY_RX_DRIVER set to 1, as a matter of fact it cannot be setted to 0, it would issue an error with the implementation of NetworkInterface.c for STM32.
if ipconfigIS_DISABLED( ipconfigZERO_COPY_RX_DRIVER )
    error "ipconfigZERO_COPY_RX_DRIVER must be enabled for NetworkInterface"
endif
Using PG’s fix I’ve got it working, while it seems to output a lot of “HAL_ETH_RxAllocateCallback: failed\n” it keep responding to pings.
Is there a way to stop HAL_ETH_RxAllocateCallback: failed from happening in the first place? At least shouldn’t PG’s proposition be merged into freertos-plus-tcp for it to work more reliably? If everyone ends up using it, it would make sense that it becomes part of the base repository, and it would make it feels “safer” to use.
Thank you by advance for any help.
My ipconfig :
 * FreeRTOS+TCP
 * Copyright (C) 2022 Amazon.com, Inc. or its affiliates.  All Rights Reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a copy of
 * this software and associated documentation files (the "Software"), to deal in
 * the Software without restriction, including without limitation the rights to
 * use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
 * the Software, and to permit persons to whom the Software is furnished to do so,
 * subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in all
 * copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
 * FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
 * COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
 * IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
 * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
 * http://aws.amazon.com/freertos
 * http://www.FreeRTOS.org
* See the following URL for configuration information.
* http://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_TCP/TCP_IP_Configuration.html
#ifndef FREERTOS_IP_CONFIG_H
#define FREERTOS_IP_CONFIG_H
#define ipconfigUSE_DHCPv6                         0
#define ipconfigUSE_IPv6                           0
#define ipconfigIPv4_BACKWARD_COMPATIBLE           1
#define ipconfigUSE_IPv4                           1
#define ipconfigUSE_ARP_REVERSED_LOOKUP            1
#define ipconfigUSE_ARP_REMOVE_ENTRY               1
#define ipconfigARP_STORES_REMOTE_ADDRESSES        1
#define ipconfigUSE_LINKED_RX_MESSAGES             0
#define ipconfigFORCE_IP_DONT_FRAGMENT             1
#define ipconfigUDP_PASS_ZERO_CHECKSUM_PACKETS     1
#define ipconfigDHCP_FALL_BACK_AUTO_IP             1
#define ipconfigARP_USE_CLASH_DETECTION            0
#define ipconfigUSE_LLMNR                          0
#define ipconfigUSE_NBNS                           0
#define ipconfigUSE_MDNS                           0
#define ipconfigSUPPORT_OUTGOING_PINGS             0
#define ipconfigETHERNET_DRIVER_FILTERS_PACKETS    0
#define ipconfigZERO_COPY_TX_DRIVER                1
#define ipconfigZERO_COPY_RX_DRIVER                1
#define ipconfigDRIVER_INCLUDED_TX_IP_CHECKSUM     1
#define ipconfigSOCKET_HAS_USER_SEMAPHORE          0
#define ipconfigSELECT_USES_NOTIFY                 1
#define ipconfigSUPPORT_SIGNALS                    1
#define ipconfigPROCESS_CUSTOM_ETHERNET_FRAMES     0
#define ipconfigDNS_USE_CALLBACKS                  0
#define ipconfigCOMPATIBLE_WITH_SINGLE             1
#define ipconfigIGNORE_UNKNOWN_PACKETS             0
#define ipconfigCHECK_IP_QUEUE_SPACE               1
#define ipconfigUDP_MAX_RX_PACKETS                 1
#define ipconfigETHERNET_MINIMUM_PACKET_BYTES      42
#define ipconfigTCP_IP_SANITY                      1
#define ipconfigSUPPORT_NETWORK_DOWN_EVENT         1
/* Set to 1 to print out debug messages.  If ipconfigHAS_DEBUG_PRINTF is set to
 * 1 then FreeRTOS_debug_printf should be defined to the function used to print
 * out the debugging messages. */
#define ipconfigHAS_DEBUG_PRINTF                   1
#if ( ipconfigHAS_DEBUG_PRINTF == 1 )
    #define FreeRTOS_debug_printf( X )    printf X
/* Set to 1 to print out non debugging messages, for example the output of the
 * FreeRTOS_netstat() command, and ping replies.  If ipconfigHAS_PRINTF is set to 1
 * then FreeRTOS_printf should be set to the function used to print out the
 * messages. */
#define ipconfigHAS_PRINTF    1
#if ( ipconfigHAS_PRINTF == 1 )
    #define FreeRTOS_printf( X )    printf X
/* Define the byte order of the target MCU (the MCU FreeRTOS+TCP is executing
 * on).  Valid options are pdFREERTOS_BIG_ENDIAN and pdFREERTOS_LITTLE_ENDIAN. */
#define ipconfigBYTE_ORDER                         pdFREERTOS_LITTLE_ENDIAN
/* If the network card/driver includes checksum offloading then set
 * ipconfigDRIVER_INCLUDED_RX_IP_CHECKSUM to 1 to prevent the software
 * stack repeating the checksum calculations. */
#define ipconfigDRIVER_INCLUDED_RX_IP_CHECKSUM     1
/* Several API's will block until the result is known, or the action has been
 * performed, for example FreeRTOS_send() and FreeRTOS_recv().  The timeouts can be
 * set per socket, using setsockopt().  If not set, the times below will be
 * used as defaults. */
#define ipconfigSOCK_DEFAULT_RECEIVE_BLOCK_TIME    ( 5000 )
#define ipconfigSOCK_DEFAULT_SEND_BLOCK_TIME       ( 5000 )
/* Include support for DNS caching.  For TCP, having a small DNS cache is very
 * useful.  When a cache is present, ipconfigDNS_REQUEST_ATTEMPTS can be kept low
 * and also DNS may use small timeouts.  If a DNS reply comes in after the DNS
 * socket has been destroyed, the result will be stored into the cache.  The next
 * call to FreeRTOS_gethostbyname() will return immediately, without even creating
 * a socket.
#define ipconfigUSE_DNS_CACHE                      ( 1 )
#define ipconfigDNS_CACHE_ADDRESSES_PER_ENTRY      ( 6 )
#define ipconfigDNS_REQUEST_ATTEMPTS               ( 2 )
/* The IP stack executes it its own task (although any application task can make
 * use of its services through the published sockets API). ipconfigUDP_TASK_PRIORITY
 * sets the priority of the task that executes the IP stack.  The priority is a
 * standard FreeRTOS task priority so can take any value from 0 (the lowest
 * priority) to (configMAX_PRIORITIES - 1) (the highest priority).
 * configMAX_PRIORITIES is a standard FreeRTOS configuration parameter defined in
 * FreeRTOSConfig.h, not FreeRTOSIPConfig.h. Consideration needs to be given as to
 * the priority assigned to the task executing the IP stack relative to the
 * priority assigned to tasks that use the IP stack. */
#define ipconfigIP_TASK_PRIORITY                   ( configMAX_PRIORITIES - 2 )
/* The size, in words (not bytes), of the stack allocated to the FreeRTOS+TCP
 * task.  This setting is less important when the FreeRTOS Win32 simulator is used
 * as the Win32 simulator only stores a fixed amount of information on the task
 * stack.  FreeRTOS includes optional stack overflow detection, see:
 * http://www.freertos.org/Stacks-and-stack-overflow-checking.html. */
#define ipconfigIP_TASK_STACK_SIZE_WORDS           ( configMINIMAL_STACK_SIZE * 5 )
/* If ipconfigUSE_NETWORK_EVENT_HOOK is set to 1 then FreeRTOS+TCP will call the
 * network event hook at the appropriate times.  If ipconfigUSE_NETWORK_EVENT_HOOK
 * is not set to 1 then the network event hook will never be called. See:
 * https://freertos.org/Documentation/03-Libraries/02-FreeRTOS-plus/02-FreeRTOS-plus-TCP/09-API-reference/57-vApplicationIPNetworkEventHook.
#define ipconfigUSE_NETWORK_EVENT_HOOK             1
/* Sockets have a send block time attribute.  If FreeRTOS_sendto() is called but
 * a network buffer cannot be obtained then the calling task is held in the Blocked
 * state (so other tasks can continue to executed) until either a network buffer
 * becomes available or the send block time expires.  If the send block time expires
 * then the send operation is aborted.  The maximum allowable send block time is
 * capped to the value set by ipconfigMAX_SEND_BLOCK_TIME_TICKS.  Capping the
 * maximum allowable send block time prevents prevents a deadlock occurring when
 * all the network buffers are in use and the tasks that process (and subsequently
 * free) the network buffers are themselves blocked waiting for a network buffer.
 * ipconfigMAX_SEND_BLOCK_TIME_TICKS is specified in RTOS ticks. A time in
 * milliseconds can be converted to a time in ticks using pdMS_TO_TICKS().*/
#define ipconfigUDP_MAX_SEND_BLOCK_TIME_TICKS      pdMS_TO_TICKS( 5000U )
/* If ipconfigUSE_DHCP is 1 then FreeRTOS+TCP will attempt to retrieve an IP
 * address, netmask, DNS server address and gateway address from a DHCP server.  If
 * ipconfigUSE_DHCP is 0 then FreeRTOS+TCP will use a static IP address.  The
 * stack will revert to using the static IP address even when ipconfigUSE_DHCP is
 * set to 1 if a valid configuration cannot be obtained from a DHCP server for any
 * reason.  The static configuration used is that passed into the stack by the
 * FreeRTOS_IPInit() function call. */
#define ipconfigUSE_DHCP                           0
#define ipconfigDHCP_REGISTER_HOSTNAME             0
#define ipconfigDHCP_USES_UNICAST                  0
/* If ipconfigDHCP_USES_USER_HOOK is set to 1 then the application writer must
 * provide an implementation of the DHCP callback function,
 * xApplicationDHCPUserHook(). */
#define ipconfigUSE_DHCP_HOOK                      0
/* When ipconfigUSE_DHCP is set to 1, DHCP requests will be sent out at
 * increasing time intervals until either a reply is received from a DHCP server
 * and accepted, or the interval between transmissions reaches
 * ipconfigMAXIMUM_DISCOVER_TX_PERIOD.  The IP stack will revert to using the
 * static IP address passed as a parameter to FreeRTOS_IPInit() if the
 * re-transmission time interval reaches ipconfigMAXIMUM_DISCOVER_TX_PERIOD without
 * a DHCP reply being received. */
#define ipconfigMAXIMUM_DISCOVER_TX_PERIOD         pdMS_TO_TICKS( 120000U )
/* The ARP cache is a table that maps IP addresses to MAC addresses.  The IP
 * stack can only send a UDP message to a remove IP address if it knowns the MAC
 * address associated with the IP address, or the MAC address of the router used to
 * contact the remote IP address.  When a UDP message is received from a remote IP
 * address the MAC address and IP address are added to the ARP cache.  When a UDP
 * message is sent to a remote IP address that does not already appear in the ARP
 * cache then the UDP message is replaced by a ARP message that solicits the
 * required MAC address information.  ipconfigARP_CACHE_ENTRIES defines the maximum
 * number of entries that can exist in the ARP table at any one time. */
#define ipconfigARP_CACHE_ENTRIES                  6
/* ARP requests that do not result in an ARP response will be re-transmitted a
 * maximum of ipconfigMAX_ARP_RETRANSMISSIONS times before the ARP request is
 * aborted. */
#define ipconfigMAX_ARP_RETRANSMISSIONS            ( 5 )
/* ipconfigMAX_ARP_AGE defines the maximum time between an entry in the ARP
 * table being created or refreshed and the entry being removed because it is stale.
 * New ARP requests are sent for ARP cache entries that are nearing their maximum
 * age.  ipconfigMAX_ARP_AGE is specified in tens of seconds, so a value of 150 is
 * equal to 1500 seconds (or 25 minutes). */
#define ipconfigMAX_ARP_AGE                        150
/* Implementing FreeRTOS_inet_addr() necessitates the use of string handling
 * routines, which are relatively large.  To save code space the full
 * FreeRTOS_inet_addr() implementation is made optional, and a smaller and faster
 * alternative called FreeRTOS_inet_addr_quick() is provided.  FreeRTOS_inet_addr()
 * takes an IP in decimal dot format (for example, "192.168.0.1") as its parameter.
 * FreeRTOS_inet_addr_quick() takes an IP address as four separate numerical octets
 * (for example, 192, 168, 0, 1) as its parameters.  If
 * ipconfigINCLUDE_FULL_INET_ADDR is set to 1 then both FreeRTOS_inet_addr() and
 * FreeRTOS_indet_addr_quick() are available.  If ipconfigINCLUDE_FULL_INET_ADDR is
 * not set to 1 then only FreeRTOS_indet_addr_quick() is available. */
#define ipconfigINCLUDE_FULL_INET_ADDR             0
/* ipconfigNUM_NETWORK_BUFFER_DESCRIPTORS defines the total number of network buffer that
 * are available to the IP stack.  The total number of network buffers is limited
 * to ensure the total amount of RAM that can be consumed by the IP stack is capped
 * to a pre-determinable value. */
#define ipconfigNUM_NETWORK_BUFFER_DESCRIPTORS     64
/* A FreeRTOS queue is used to send events from application tasks to the IP
 * stack.  ipconfigEVENT_QUEUE_LENGTH sets the maximum number of events that can
 * be queued for processing at any one time.  The event queue must be a minimum of
 * 5 greater than the total number of network buffers. */
#define ipconfigEVENT_QUEUE_LENGTH \
    ( ipconfigNUM_NETWORK_BUFFER_DESCRIPTORS + 5 )
/* The address of a socket is the combination of its IP address and its port
 * number.  FreeRTOS_bind() is used to manually allocate a port number to a socket
 * (to 'bind' the socket to a port), but manual binding is not normally necessary
 * for client sockets (those sockets that initiate outgoing connections rather than
 * wait for incoming connections on a known port number).  If
 * ipconfigALLOW_SOCKET_SEND_WITHOUT_BIND is set to 1 then calling
 * FreeRTOS_sendto() on a socket that has not yet been bound will result in the IP
 * stack automatically binding the socket to a port number from the range
 * socketAUTO_PORT_ALLOCATION_START_NUMBER to 0xffff.  If
 * ipconfigALLOW_SOCKET_SEND_WITHOUT_BIND is set to 0 then calling FreeRTOS_sendto()
 * on a socket that has not yet been bound will result in the send operation being
 * aborted. */
#define ipconfigALLOW_SOCKET_SEND_WITHOUT_BIND         1
/* Defines the Time To Live (TTL) values used in outgoing UDP packets. */
#define ipconfigUDP_TIME_TO_LIVE                       128
/* Also defined in FreeRTOSIPConfigDefaults.h. */
#define ipconfigTCP_TIME_TO_LIVE                       128
/* USE_TCP: Use TCP and all its features. */
#define ipconfigUSE_TCP                                ( 0 )
/* USE_WIN: Let TCP use windowing mechanism. */
#define ipconfigUSE_TCP_WIN                            ( 0 )
/* The MTU is the maximum number of bytes the payload of a network frame can
 * contain.  For normal Ethernet V2 frames the maximum MTU is 1500.  Setting a
 * lower value can save RAM, depending on the buffer management scheme used.  If
 * ipconfigCAN_FRAGMENT_OUTGOING_PACKETS is 1 then (ipconfigNETWORK_MTU - 28) must
 * be divisible by 8. */
#define ipconfigNETWORK_MTU                            1500U
/* Set ipconfigUSE_DNS to 1 to include a basic DNS client/resolver.  DNS is used
 * through the FreeRTOS_gethostbyname() API function. */
#define ipconfigUSE_DNS                                0
/* If ipconfigREPLY_TO_INCOMING_PINGS is set to 1 then the IP stack will
 * generate replies to incoming ICMP echo (ping) requests. */
#define ipconfigREPLY_TO_INCOMING_PINGS                1
/* If ipconfigSUPPORT_OUTGOING_PINGS is set to 1 then the
 * FreeRTOS_SendPingRequest() API function is available. */
/* If ipconfigSUPPORT_SELECT_FUNCTION is set to 1 then the FreeRTOS_select()
 * (and associated) API function is available. */
#define ipconfigSUPPORT_SELECT_FUNCTION                0
/* If ipconfigFILTER_OUT_NON_ETHERNET_II_FRAMES is set to 1 then Ethernet frames
 * that are not in Ethernet II format will be dropped.  This option is included for
 * potential future IP stack developments. */
#define ipconfigFILTER_OUT_NON_ETHERNET_II_FRAMES      1
/* If ipconfigETHERNET_DRIVER_FILTERS_FRAME_TYPES is set to 1 then it is the
 * responsibility of the Ethernet interface to filter out packets that are of no
 * interest.  If the Ethernet interface does not implement this functionality, then
 * set ipconfigETHERNET_DRIVER_FILTERS_FRAME_TYPES to 0 to have the IP stack
 * perform the filtering instead (it is much less efficient for the stack to do it
 * because the packet will already have been passed into the stack).  If the
 * Ethernet driver does all the necessary filtering in hardware then software
 * filtering can be removed by using a value other than 1 or 0. */
#define ipconfigETHERNET_DRIVER_FILTERS_FRAME_TYPES    0
/* The windows simulator cannot really simulate MAC interrupts, and needs to
 * block occasionally to allow other tasks to run. */
#define configWINDOWS_MAC_INTERRUPT_SIMULATOR_DELAY    pdMS_TO_TICKS( 20 )
/* Advanced only: in order to access 32-bit fields in the IP packets with
 * 32-bit memory instructions, all packets will be stored 32-bit-aligned,
 * plus 16-bits. This has to do with the contents of the IP-packets: all
 * 32-bit fields are 32-bit-aligned, plus 16-bit. */
#define ipconfigPACKET_FILLER_SIZE                     2U
/* Define the size of the pool of TCP window descriptors.  On the average, each
 * TCP socket will use up to 2 x 6 descriptors, meaning that it can have 2 x 6
 * outstanding packets (for Rx and Tx).  When using up to 10 TP sockets
 * simultaneously, one could define TCP_WIN_SEG_COUNT as 120. */
#define ipconfigTCP_WIN_SEG_COUNT                      240
/* Each TCP socket has a circular buffers for Rx and Tx, which have a fixed
 * maximum size.  Define the size of Rx buffer for TCP sockets. */
#define ipconfigTCP_RX_BUFFER_LENGTH                   ( 10000 )
/* Define the size of Tx buffer for TCP sockets. */
#define ipconfigTCP_TX_BUFFER_LENGTH                   ( 10000 )
/* When using call-back handlers, the driver may check if the handler points to
 * real program memory (RAM or flash) or just has a random non-zero value. */
#define ipconfigIS_VALID_PROG_ADDRESS( x )    ( ( x ) != NULL )
/* Include support for TCP keep-alive messages. */
#define ipconfigTCP_KEEP_ALIVE                   ( 1 )
#define ipconfigTCP_KEEP_ALIVE_INTERVAL          ( 20 ) /* Seconds. */
#define ipconfigSOCKET_HAS_USER_WAKE_CALLBACK    ( 1 )
#define ipconfigUSE_CALLBACKS                    ( 1 )
#define portINLINE                               __inline
#define ipconfigISO_STRICTNESS_VIOLATION_START \
    _Pragma("GCC diagnostic push")             \
    _Pragma("GCC diagnostic ignored \"-Wpedantic\"")
#define ipconfigISO_STRICTNESS_VIOLATION_END    _Pragma("GCC diagnostic pop")
#endif /* FREERTOS_IP_CONFIG_H */
@htibosch What do you think about it?
@bjolaine My demo with the H7 was a little contrived. I wouldn’t expect the buffer exhaustion to happen unless you were debugging as I was when I first triggered it. Or you were processing traffic in a very low priority task, which allowed the UDP packets to queue up. My demo did just this deliberately. Our product shipped initially with the bug and our customers didn’t see the issue. When working on a separate product using the same codebase, attempting to push UDP traffic much faster I started to encounter it myself. I spent several days digging into before finding the cause.
A big problem I hit with the H7 and the stock freertos IP stack which required a separate fix before shipping our product, it wasn’t responding to ARP requests. The stack was only working as it was sending out gratuitous ARP messages. I’ve been maintaining my own IP stack fork here: Comparing FreeRTOS:V4.3.4...pgreenland:4.3.4_t1_phy · FreeRTOS/FreeRTOS-Plus-TCP · GitHub
We use T1 automotive Ethernet, I’ve been hacking at the phy init code, ignore that its not pretty.
This particular commit gets ARP working properly again: Enable reception of broadcast packets for ARP · FreeRTOS/FreeRTOS-Plus-TCP@b73113f · GitHub
This is the other commit you mentioned that retries RX allocations:
It would be good to get them into the mainline, I’m amazed others haven’t hit similar things with the H7 port.
Phil
@pgreenland Hi!
That’s possible, I’ll try to higher the priority, It may not need the fix anymore (at least it may stop failing to allocate as much).
Though I don’t think that crashing after a handful of Rx failures is an adequate behavior for the networkInterface. Thank you for providing the fix.
Do you mean it is only working because it’s sending ARP messages in continue? That’s weird too. How did you find out about these ? I did not saw it but I’ll admit I’m in an early development phase.
I agree, I expected more stability, my guess is the lwip stack provided by a CubeMX code generation is used more often than freeRTOS-plus-TCP on STM32, which would explain less people encounter those bugs. I hope it’ll get merged.
Thanks again,
Baptiste
Hey @bjolaine ,
I spotted that our client side application was occasionally taking multiple seconds to “connect” (start replying to UDP packets). Not all the time but after a period of inactivity. Spotted in wireshark that the ARP requests sent by my laptop weren’t being responded to by the unit. The times when it did reply lined up with the gratuatus ARP requests periodically sent by the stack.
I’ve used LWIP in a bare metal project in the past, but for FreeRTOS was hoping their stack might be a better match.
Have avoided all the bundled extras in CubeMX. It’s pretty good for pin mapping and driver configuration but their FreeRTOS version was outdated last time I looked.
I’ve limited CubeMX for the low level stuff and added FreeRTOS and friends manually.
With the few little issued I found sorted it’s been rock solid. I was hoping others might be able to reproduce them highlighting the need for a fix of some sort. Be it mine or something neater.
Thanks,
Phil
There are a couple of known bugs in the new network interface I made but they are really simple fixes. You can find some of them in PRs on the FreeRTOS TCP repo. I’d also update the ethernet hal drivers from stm because the older hal drivers had bugs in them as well
Edit: Actually I closed my PRs with the fixes but you can still find them
Hi!
Nice, can you link your merge requests?
Why have those been closed? It would be useful to reopen them if it’s still relevant.
Thanks for your work,
Baptiste
Not a whole lot of active development so I moved on to other things
