lukas-eco wrote on Tuesday, October 11, 2016:
I’m trying to use FreeRTOS + UDP in a STM Discovery board.
It initilize fine and get a ip address from DHCP when I plug it on my router.
But there is a problem when I send a PING request from my computer, I receive about 12 packets and after that all the next packets are lost. Other issue is that I have tried to send a ping request from my board with no sucess.
Both times, send a ping from my computer or to my computer, I put a led blink task to run togheter my application and it doesn’t stop even when my UDP/IP stops to handle the packets.
*Using a led to debug I saw that my UDP stops when, in my handle task, the function pxNetworkBufferGet( xBytesReceived, 0 ) starts to return NULL.
Probably my problem is on my network interface implementation. Here is the code.
* FreeRTOS+UDP V1.0.4 (C) 2014 Real Time Engineers ltd.
* All rights reserved
* This file is part of the FreeRTOS+UDP distribution. The FreeRTOS+UDP license
* terms are different to the FreeRTOS license terms.
* FreeRTOS+UDP uses a dual license model that allows the software to be used
* under a standard GPL open source license, or a commercial license. The
* standard GPL license (unlike the modified GPL license under which FreeRTOS
* itself is distributed) requires that all software statically linked with
* FreeRTOS+UDP is also distributed under the same GPL V2 license terms.
* Details of both license options follow:
* - Open source licensing -
* FreeRTOS+UDP is a free download and may be used, modified, evaluated and
* distributed without charge provided the user adheres to version two of the
* GNU General Public License (GPL) and does not remove the copyright notice or
* this text. The GPL V2 text is available on the gnu.org web site, and on the
* following URL: http://www.FreeRTOS.org/gpl-2.0.txt.
* - Commercial licensing -
* Businesses and individuals that for commercial or other reasons cannot comply
* with the terms of the GPL V2 license must obtain a commercial license before
* incorporating FreeRTOS+UDP into proprietary software for distribution in any
* form. Commercial licenses can be purchased from http://shop.freertos.org/udp
* and do not require any source files to be changed.
* FreeRTOS+UDP is distributed in the hope that it will be useful. You cannot
* use FreeRTOS+UDP unless you agree that you use the software 'as is'.
* FreeRTOS+UDP is provided WITHOUT ANY WARRANTY; without even the implied
* warranties of NON-INFRINGEMENT, MERCHANTABILITY or FITNESS FOR A PARTICULAR
* PURPOSE. Real Time Engineers Ltd. disclaims all conditions and terms, be they
* implied, expressed, or statutory.
* 1 tab == 4 spaces!
* http://www.FreeRTOS.org
* http://www.FreeRTOS.org/udp
/* Standard includes. */
#include <stdint.h>
#include <stdlib.h>
#include <stdio.h>
/* FreeRTOS includes. */
#include "FreeRTOS.h"
#include "task.h"
#include "queue.h"
#include "semphr.h"
/* Hardware abstraction. */
/* FreeRTOS+UDP includes. */
#include "FreeRTOS_UDP_IP.h"
#include "FreeRTOS_IP_Private.h"
#include "FreeRTOS_Sockets.h"
#include "NetworkBufferManagement.h"
/* Driver includes. */
#include "enet_mac.h"
#include "metal/systime.h"
#include "metal/delay.h"
/* Demo includes. */
#include "NetworkInterface.h"
/* When a packet is ready to be sent, if it cannot be sent immediately then the
task performing the transmit will block for niTX_BUFFER_FREE_WAIT
milliseconds. It will do this a maximum of niMAX_TX_ATTEMPTS before giving
up. */
#define niTX_BUFFER_FREE_WAIT ( ( TickType_t ) 2UL / portTICK_RATE_MS )
#define niMAX_TX_ATTEMPTS ( 5 )
* A deferred interrupt handler task that processes
static void prvEMACHandlerTask( void *pvParameters );
/* The queue used to communicate Ethernet events with the IP task. */
extern xQueueHandle xNetworkEventQueue;
/* The semaphore used to wake the deferred interrupt handler task when an Rx
interrupt is received. */
static xSemaphoreHandle xEMACRxEventSemaphore = NULL;
#ifndef ENET_PHY_ADDR
# define ENET_PHY_ADDR 0x00
#define ENET_NBUF 1024
#define ENET_DMA_NRXD 15
#define ENET_DMA_NTXD 15
typedef struct enet_dma_desc
volatile uint32_t des0;
volatile uint32_t des1;
volatile uint32_t des2;
volatile uint32_t des3;
} enet_dma_desc_t;
#define ALIGN4 __attribute__((aligned(4)));
static volatile enet_dma_desc_t g_enet_dma_rx_desc[ENET_DMA_NRXD] ALIGN4;
static volatile enet_dma_desc_t g_enet_dma_tx_desc[ENET_DMA_NTXD] ALIGN4;
static volatile uint8_t g_enet_dma_rx_buf[ENET_DMA_NRXD][ENET_NBUF] ALIGN4;
static volatile uint8_t g_enet_dma_tx_buf[ENET_DMA_NTXD][ENET_NBUF] ALIGN4;
static volatile enet_dma_desc_t *g_enet_dma_rx_next_desc = &g_enet_dma_rx_desc[0];
static volatile enet_dma_desc_t *g_enet_dma_tx_next_desc = &g_enet_dma_tx_desc[0];
uint8_t *buffer;
uint16_t enet_read_phy_reg( const uint8_t reg_idx )
while( ETH->MACMIIAR & ETH_MACMIIAR_MB ){}
ETH->MACMIIAR = ( ENET_PHY_ADDR << 11 ) | ( ( reg_idx & 0x1F ) << 6 ) | ETH_MACMIIAR_CR_Div102 | ETH_MACMIIAR_MB;
return ETH->MACMIIDR & 0xFFFF;
void enet_write_phy_reg( const uint8_t reg_idx, const uint16_t reg_val )
ETH->MACMIIDR = reg_val;
ETH->MACMIIAR = ( ENET_PHY_ADDR << 11 ) | ( ( reg_idx & 0x1F ) << 6 ) | ETH_MACMIIAR_CR_Div102 | ETH_MACMIIAR_MW | ETH_MACMIIAR_MB;
enet_read_phy_reg( reg_idx );
BaseType_t xNetworkInterfaceInitialise( void )
buffer = ( char* )malloc( 1024 );
BaseType_t xReturn;
enet_mac_init_pins();
RCC->APB2ENR |= RCC_APB2ENR_SYSCFGEN;
RCC->AHB1RSTR |= RCC_AHB1RSTR_ETHMACRST;
for( volatile int i = 0; i < 1000; i++ ){}
#ifndef ENET_USE_MII
SYSCFG->PMC |= SYSCFG_PMC_MII_RMII_SEL; // set the MAC in RMII mode
for( volatile int i = 0; i < 100000; i++ ){}
RCC->AHB1ENR |= RCC_AHB1ENR_ETHMACRXEN | RCC_AHB1ENR_ETHMACTXEN | RCC_AHB1ENR_ETHMACEN;
RCC->AHB1RSTR &= ~RCC_AHB1RSTR_ETHMACRST;
ETH->DMABMR |= ETH_DMABMR_SR;
while( ETH->DMABMR & ETH_DMABMR_SR ){}
ETH->DMAOMR |= ETH_DMAOMR_FTF;
while( ETH->DMAOMR & ETH_DMAOMR_FTF ){}
ETH->MACCR |= 0x02000000 | ETH_MACCR_FES | ETH_MACCR_DM | ETH_MACCR_IPCO | ETH_MACCR_APCS;
ETH->MACFFR |= ETH_MACFFR_RA;
delay_ms( 1 );
while( enet_read_phy_reg( 0 ) == 0xffff ){}
for( int i = 0; i < ENET_DMA_NTXD; i++ )
g_enet_dma_tx_desc[i].des0 = 0x00100000 | 0x00c00000;
g_enet_dma_tx_desc[i].des1 = 0;
g_enet_dma_tx_desc[i].des2 = ( uint32_t )&g_enet_dma_tx_buf[ i ][ 0 ];
if( i < ENET_DMA_NTXD - 1 )
g_enet_dma_tx_desc[ i ].des3 = ( uint32_t )&g_enet_dma_tx_desc[ i + 1 ];
g_enet_dma_tx_desc[ i ].des3 = ( uint32_t )&g_enet_dma_tx_desc[ 0 ];
for( int i = 0; i < ENET_DMA_NRXD; i++ )
g_enet_dma_rx_desc[ i ].des0 = 0x80000000;
g_enet_dma_rx_desc[ i ].des1 = 0x00004000 | ENET_NBUF;
g_enet_dma_rx_desc[ i ].des2 = (uint32_t)&g_enet_dma_rx_buf[ i ][ 0 ];
if( i < ENET_DMA_NRXD - 1 )
g_enet_dma_rx_desc[ i ].des3 = ( uint32_t )&g_enet_dma_rx_desc[ i + 1 ];
g_enet_dma_rx_desc[ i ].des3 = ( uint32_t )&g_enet_dma_rx_desc[ 0 ];
ETH->DMATDLAR = ( uint32_t )&g_enet_dma_tx_desc[ 0 ];
ETH->DMARDLAR = ( uint32_t )&g_enet_dma_rx_desc[ 0 ];
ETH->DMAOMR = ETH_DMAOMR_TSF;
ETH->DMABMR |= ETH_DMABMR_AAB;
ETH->DMAIER = ETH_DMAIER_NISE | ETH_DMAIER_RIE;
ETH->MACCR |= ETH_MACCR_TE | ETH_MACCR_RE;
//How to know if the hardware was not initilizes corretly
if( 1 )
if( xEMACRxEventSemaphore == NULL )
vSemaphoreCreateBinary( xEMACRxEventSemaphore );
configASSERT( xEMACRxEventSemaphore );
/* The handler task is created at the highest possible priority to
ensure the interrupt handler can return directly to it. */
xTaskCreate( prvEMACHandlerTask, "EMAC", configMINIMAL_STACK_SIZE, NULL, configMAX_PRIORITIES - 1, NULL );
/* Enable the interrupt and set its priority to the minimum
interrupt priority. */
NVIC_SetPriority( ETH_IRQn, 8 );
NVIC_EnableIRQ( ETH_IRQn );
ETH->DMAOMR |= ETH_DMAOMR_ST | ETH_DMAOMR_SR;
xReturn = pdPASS;
xReturn = pdFAIL;
return xReturn;
BaseType_t xNetworkInterfaceOutput( xNetworkBufferDescriptor_t * const pxNetworkBuffer )
BaseType_t xReturn = pdFAIL;
int32_t x;
volatile uint32_t tps;
/* Attempt to obtain access to a Tx buffer. */
for( x = 0; x < niMAX_TX_ATTEMPTS; x++ )
/* Verify if the DMA descriptor are free to send a frame */
if( !( g_enet_dma_tx_next_desc->des0 & 0x80000000 ) )
/* Will the data fit in the Tx buffer? */
if( pxNetworkBuffer->xDataLength < ENET_NBUF ) /*_RB_ The size needs to come from FreeRTOSIPConfig.h. */
buffer = (uint8_t *)g_enet_dma_tx_next_desc->des2;
/* Assign the buffer to the Tx descriptor that is now known to
be free. */
memcpy( (uint8_t *)buffer, (uint8_t *)pxNetworkBuffer->pucEthernetBuffer, pxNetworkBuffer->xDataLength );
g_enet_dma_tx_next_desc->des1 = (uint32_t)pxNetworkBuffer->xDataLength;
/* Initiate the Tx. */
g_enet_dma_tx_next_desc->des0 |= 0x30000000 | 0x80000000;
delay_ns( 1 );
tps = ETH->DMASR & ETH_DMASR_TPS;
/* Verify if the DMA is suspended.If it is, put it to run again and transmit the descriptors*/
if( tps == ETH_DMASR_TPS_Suspended )
ETH->DMATPDR = 0;
/* Set DMA descriptor to the next transmition descriptor */
g_enet_dma_tx_next_desc = (enet_dma_desc_t *)g_enet_dma_tx_next_desc->des3;
/* The EMAC now owns the buffer. */
pxNetworkBuffer->pucEthernetBuffer = NULL;
/* The Tx has been initiated. */
xReturn = pdPASS;
break;
vTaskDelay( niTX_BUFFER_FREE_WAIT );
/* Finished with the network buffer. */
vNetworkBufferRelease( pxNetworkBuffer );
return xReturn;
void eth_vector( void )
volatile uint32_t dmasr = ETH->DMASR;
portBASE_TYPE xHigherPriorityTaskWoken;
ETH->DMASR = dmasr;
if( dmasr & ETH_DMASR_RS )
xSemaphoreGiveFromISR( xEMACRxEventSemaphore, &xHigherPriorityTaskWoken );
/* ulInterruptCause is used for convenience here. A context switch is
wanted, but coding portEND_SWITCHING_ISR( 1 ) would likely result in a
compiler warning. */
portEND_SWITCHING_ISR( xHigherPriorityTaskWoken );
xNetworkBufferDescriptor_t *pxNetworkBuffer;
size_t xBytesReceived;
xIPStackEvent_t xRxEvent;
( void )pvParameters;
for( ;; )
/* Wait for the Ethernet MAC interrupt to indicate that another packet
has been received. It is assumed xEMACRxEventSemaphore is a counting
semaphore (to count the Rx events) and that the semaphore has already
been created. */
while( xSemaphoreTake( xEMACRxEventSemaphore, portMAX_DELAY ) == pdFALSE );
/* At least one packet has been received. */
while( !( g_enet_dma_rx_next_desc->des0 & 0x80000000 ) )
/* See how much data was received. */
xBytesReceived = ( size_t )( ( g_enet_dma_rx_next_desc->des0 & 0x3FFF0000 ) >> 16 );
if( xBytesReceived > 0 )
/* Allocate a network buffer descriptor that references an Ethernet
buffer large enough to hold the received data. */
pxNetworkBuffer = pxNetworkBufferGet( xBytesReceived, 0 )N;
//led_toggle();
if( pxNetworkBuffer != NULL )
/* pxNetworkBuffer->pucEthernetBuffer now points to an Ethernet
buffer large enough to hold the received data. Copy the
received data into pcNetworkBuffer->pucEthernetBuffer. */
memcpy( ( uint8_t * )pxNetworkBuffer->pucEthernetBuffer, ( uint8_t * )g_enet_dma_rx_next_desc->des2, xBytesReceived );
pxNetworkBuffer->xDataLength = xBytesReceived;
/* See if the data contained in the received Ethernet frame needs
to be processed. */
if( eConsiderFrameForProcessing( pxNetworkBuffer->pucEthernetBuffer ) == eProcessBuffer )
/* The event about to be sent to the IP stack is an Rx event. */
xRxEvent.eEventType = eEthernetRxEvent;
/* pvData is used to point to the network buffer descriptor that
references the received data. */
xRxEvent.pvData = ( void * ) pxNetworkBuffer;
/* Send the data to the IP stack. */
if( xQueueSendToBack( xNetworkEventQueue, &xRxEvent, 0 ) == pdFALSE )
/* The buffer could not be sent to the IP task so the buffer
must be released. */
/* The message was successfully sent to the IP stack. */
/* The Ethernet frame can be dropped, but the Ethernet buffer
/* RX event lost */
g_enet_dma_rx_next_desc->des0 |= 0x80000000;
g_enet_dma_rx_next_desc = ( enet_dma_desc_t * )g_enet_dma_rx_next_desc->des3;
