debugasm wrote on Friday, July 28, 2017:
Today I finally got to try FreeRTOS+TCP using MicroBlaze and EthernetLite on
Spartan6 FPGA.
I am very happy because in my next project I want to use FreeRTOS+TCP instead
of lwip.
I still have to do many tests and write a lot of code but I think that
FreeRTOS+TCP will give me a lot of satisfaction, thanks to the excellent work
that has been done up to here from the “Real Time Engineers ltd”.
In my appliances I always use a static IP address, I do not use DHCP (which I
have disabled) and for now I set the IP address hardcoded.
I have a problem though: How to change IP address when started FreeRTOS+TCP ?
I did not find any APIs for that, was not considered ?
I have found this :
FreeRTOS_SetIPAddress
FreeRTOS_SetNetmask
FreeRTOS_SetGatewayAddress
But missing :
FreeRTOS_SetDNS
But these routines do not seem appropriate to what I see in the code.
How do I change my network configuration after I have started FreeRTOS+TCP with
another manually assigned IP address ?
Suggestion:
While porting the EthernetLite driver I noticed that the call to:
BaseType_t xNetworkInterfaceInitialise( void )
does not pass the MAC address to be set to the EMAC interface, but it is
necessary to refer to an external variable:
/* ucMACAddress as it appears in main.c */
extern const uint8_t ucMACAddress[ 6 ];
Would not it be better to pass the MAC value as a parameter ?
There is an upgrade after “160919_FreeRTOS_Labs.zip” ?
Thanks so much.
debugasm
