FreeRTOS+TCP for STM32H7?
In @Heinrich-vanNieuwenh’s repo you will find a main.c in CM7/Core/Src.
It was written for a NUCLEO-H745ZI. I don’t know the exact differences with your H743 Nucleo board.
Here is my main()
// Initialize GPIOs for Ethernet here
FreeRTOS_IPInit( ucIPAddress,
ucNetMask,
ucGatewayAddress,
ucDNSServerAddress,
ucMACAddress );
vTaskStartScheduler();
for(;;) {}
Beside calling FreeRTOS_IPInit(), it is very important to set the clocks of the CPU:
    /* Configure the system clock */
    SystemClock_Config();
Also, as described in the readme.md, you will have to define a RAM section that can be used for DMA.
Here is the latest version of the STM32H7 driver.
It looks like many developers were waiting for a FreeRTOS+TCP driver for the STM32Hx, and several people had questions about the application code, the CPU-setup, and the memories.
Therefore I have decided to publish my testing project on Github here.
This is not an official release from AWS/FreeRTOS, it is just a help to get your project running.
It is a complete project, and it includes the latest releases of the FreeRTOS kernel, +TCP, and ST’s HAL.
It also has a small demonstration of the RNG peripheral, which is important for Internet security.
Thank you,
I forgot to include the clock configuration in the original post. However, after connecting to the debugger, I was able to determine that I was getting DMA errors (Fatal bus error + Receive Process stopped). After adding the following to the linker script:
.eth_desc (NOLOAD) : {
    . = ABSOLUTE(0x30040000);
    *(.RxDecripSection)
    . = ABSOLUTE(0x30040060);
    *(.TxDecripSection)
    . = ABSOLUTE(0x30040200);
    *(.RxArraySection)
} >RAM_D2 AT> FLASH
and configuring the MPU as described here, everything worked correctly! Now to move on to MQTT…
Thank you again!
The STM32H7 FreeRTOS+TCP drivers for STM32H7 are now part of the FreeRTOS 202012.00 and FreeRTOS-LTS releases.
I got the driver working on a few versions of a custom STM32H753 board, but have not validated the speed.
It is also worth nothing that when enabling Ethernet in the STM32CubeIDE GUI, the ETH_DMADescTypeDef DMARxDscrTab / DMATxDscrTab, RxBuff, ETH_TxPacketConfig and ETH_HandleTypeDef variables are generated inside main.c. To make this driver work with these variables instead, simply make NetworkInterface.c reference them instead of the ones included in the file. Also make sure to enable I cache, disable D cache, delete the stm32h7xx_hal_eth files generated by the UI, and to enable the ethernet interrupt.
I’m having issues with low clock speeds not working (DHCP request not detected by my router). I have to use VOS0 and CPU speed of 400 MHz to get the thing to work. I suspect a hardware problem on my side. I’ll update if I find an official document related to clock speed issues with ETH driver.
EDIT: Confirming this is a hardware issue on my side as Ethernet works with VOS2 and 200 MHz SYSCLK and MCU CLK on a previous version. I suspect it’s due to either the rough rework I did after a bad reflow, or to the underpowered 25 MHz clock trying to supply both the MAC and the MCU without a buffer :smiley: .
Thanks to @htibosch and everyone who contributed to this driver.
Can someone share any example ready to go and test with STM32H755. It would be great if someone has the UDP echo project up and working on STM32H755.
@iftikhares
You can take a look at this repository: GitHub - tony-josi-aws/STM32_Nucleo_H723ZG_FreeRTOS_TCP
Although the project is for STM32 H723ZG NUCLEO, you should be able to get it running on H755 with minor changes.
The above project has a UDP example in this path: STM32_Nucleo_H723ZG_FreeRTOS_TCP/Libraries/FreeRTOS-Plus-CLI/UDPEchoClient_SingleTasks.c at master · tony-josi-aws/STM32_Nucleo_H723ZG_FreeRTOS_TCP · GitHub
Thank you @tony-josi-aws.
I have imported the project as is, however i see many errors as there is obivously FreeRTOS.c and FreeRTOS.h etc are missing. See picture below;
I ran the IOC file and found the FreeRTOS option is not selected and I enabled it and let the IDE add the FreeRTOS. See picture below ;
By doing so, the main.c has been modified by the IDE which doesnt seem to be correct anymore.
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * Copyright (c) 2023 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "cmsis_os.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include <string.h>
#include "FreeRTOS.h"
#include "task.h"
#include "FreeRTOS_IP.h"
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
#define LED_HW			1
#define TCP_CLI			1
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
RNG_HandleTypeDef hrng;
UART_HandleTypeDef huart3;
/* Definitions for defaultTask */
osThreadId_t defaultTaskHandle;
const osThreadAttr_t defaultTask_attributes = {
  .name = "defaultTask",
  .stack_size = 128 * 4,
  .priority = (osPriority_t) osPriorityNormal,
/* USER CODE BEGIN PV */
#if LED_HW
static void task_1_thread_fn(void *io_params) {
	while(1) {
		HAL_GPIO_TogglePin(GPIOE, GPIO_PIN_1);
		vTaskDelay(100);
static void task_2_thread_fn(void *io_params) {
	while(1) {
		HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_14);
		vTaskDelay(200);
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART3_UART_Init(void);
static void MX_USB_OTG_HS_USB_Init(void);
static void MX_RNG_Init(void);
void StartDefaultTask(void *argument);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_USART3_UART_Init();
  MX_USB_OTG_HS_USB_Init();
  MX_RNG_Init();
  /* USER CODE BEGIN 2 */
#if LED_HW
  TaskHandle_t task_1_handle, task_2_handle;
  BaseType_t ret_status;
  ret_status = xTaskCreate(task_1_thread_fn, "Task_1", 200, "HW from 1", 2, &task_1_handle);
  configASSERT(ret_status == pdPASS);
  ret_status = xTaskCreate(task_2_thread_fn, "Task_2", 200, "HW from 2", 2, &task_2_handle);
#elif TCP_CLI
  extern void app_main( void );
  app_main();
  /* USER CODE END 2 */
  /* Init scheduler */
  osKernelInitialize();
  /* USER CODE BEGIN RTOS_MUTEX */
  /* add mutexes, ... */
  /* USER CODE END RTOS_MUTEX */
  /* USER CODE BEGIN RTOS_SEMAPHORES */
  /* add semaphores, ... */
  /* USER CODE END RTOS_SEMAPHORES */
  /* USER CODE BEGIN RTOS_TIMERS */
  /* start timers, add new ones, ... */
  /* USER CODE END RTOS_TIMERS */
  /* USER CODE BEGIN RTOS_QUEUES */
  /* add queues, ... */
  /* USER CODE END RTOS_QUEUES */
  /* Create the thread(s) */
  /* creation of defaultTask */
  defaultTaskHandle = osThreadNew(StartDefaultTask, NULL, &defaultTask_attributes);
  /* USER CODE BEGIN RTOS_THREADS */
  /* add threads, ... */
  /* USER CODE END RTOS_THREADS */
  /* USER CODE BEGIN RTOS_EVENTS */
  /* add events, ... */
  /* USER CODE END RTOS_EVENTS */
  /* Start scheduler */
  osKernelStart();
  /* We should never get here as control is now taken by the scheduler */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Supply configuration update enable
  HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);
  /** Configure the main internal regulator output voltage
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
  while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI48|RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_DIV1;
  RCC_OscInitStruct.HSICalibrationValue = 64;
  RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
                              |RCC_CLOCKTYPE_D3PCLK1|RCC_CLOCKTYPE_D1PCLK1;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2;
  RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
    Error_Handler();
  * @brief RNG Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN RNG_Init 0 */
  /* USER CODE END RNG_Init 0 */
  /* USER CODE BEGIN RNG_Init 1 */
  /* USER CODE END RNG_Init 1 */
  hrng.Instance = RNG;
  hrng.Init.ClockErrorDetection = RNG_CED_ENABLE;
  if (HAL_RNG_Init(&hrng) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN RNG_Init 2 */
  /* USER CODE END RNG_Init 2 */
  * @brief USART3 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN USART3_Init 0 */
  /* USER CODE END USART3_Init 0 */
  /* USER CODE BEGIN USART3_Init 1 */
  /* USER CODE END USART3_Init 1 */
  huart3.Instance = USART3;
  huart3.Init.BaudRate = 115200;
  huart3.Init.WordLength = UART_WORDLENGTH_8B;
  huart3.Init.StopBits = UART_STOPBITS_1;
  huart3.Init.Parity = UART_PARITY_NONE;
  huart3.Init.Mode = UART_MODE_TX_RX;
  huart3.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart3.Init.OverSampling = UART_OVERSAMPLING_16;
  huart3.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart3.Init.ClockPrescaler = UART_PRESCALER_DIV1;
  huart3.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init(&huart3) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_SetTxFifoThreshold(&huart3, UART_TXFIFO_THRESHOLD_1_8) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_SetRxFifoThreshold(&huart3, UART_RXFIFO_THRESHOLD_1_8) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_DisableFifoMode(&huart3) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN USART3_Init 2 */
  /* USER CODE END USART3_Init 2 */
  * @brief USB_OTG_HS Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN USB_OTG_HS_Init 0 */
  /* USER CODE END USB_OTG_HS_Init 0 */
  /* USER CODE BEGIN USB_OTG_HS_Init 1 */
  /* USER CODE END USB_OTG_HS_Init 1 */
  /* USER CODE BEGIN USB_OTG_HS_Init 2 */
  /* USER CODE END USB_OTG_HS_Init 2 */
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  __HAL_RCC_GPIOG_CLK_ENABLE();
  __HAL_RCC_GPIOE_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(LED_RED_GPIO_Port, LED_RED_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(USB_FS_PWR_EN_GPIO_Port, USB_FS_PWR_EN_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(LED_YELLOW_GPIO_Port, LED_YELLOW_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pin : B1_Pin */
  GPIO_InitStruct.Pin = B1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  HAL_GPIO_Init(B1_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : RMII_MDC_Pin RMII_RXD0_Pin RMII_RXD1_Pin */
  GPIO_InitStruct.Pin = RMII_MDC_Pin|RMII_RXD0_Pin|RMII_RXD1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  GPIO_InitStruct.Alternate = GPIO_AF11_ETH;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  /*Configure GPIO pins : RMII_REF_CLK_Pin RMII_MDIO_Pin RMII_CRS_DV_Pin */
  GPIO_InitStruct.Pin = RMII_REF_CLK_Pin|RMII_MDIO_Pin|RMII_CRS_DV_Pin;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  /*Configure GPIO pins : PB0 RMII_TXD1_Pin */
  GPIO_InitStruct.Pin = GPIO_PIN_0|RMII_TXD1_Pin;
  HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  /*Configure GPIO pin : LED_RED_Pin */
  GPIO_InitStruct.Pin = LED_RED_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  HAL_GPIO_Init(LED_RED_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : USB_FS_PWR_EN_Pin */
  GPIO_InitStruct.Pin = USB_FS_PWR_EN_Pin;
  HAL_GPIO_Init(USB_FS_PWR_EN_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : USB_FS_OVCR_Pin */
  GPIO_InitStruct.Pin = USB_FS_OVCR_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
  HAL_GPIO_Init(USB_FS_OVCR_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : USB_FS_VBUS_Pin */
  GPIO_InitStruct.Pin = USB_FS_VBUS_Pin;
  HAL_GPIO_Init(USB_FS_VBUS_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : USB_FS_ID_Pin */
  GPIO_InitStruct.Pin = USB_FS_ID_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF10_OTG1_HS;
  HAL_GPIO_Init(USB_FS_ID_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : RMII_TX_EN_Pin RMII_TXD0_Pin */
  GPIO_InitStruct.Pin = RMII_TX_EN_Pin|RMII_TXD0_Pin;
  HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
  /*Configure GPIO pin : LED_YELLOW_Pin */
  GPIO_InitStruct.Pin = LED_YELLOW_Pin;
  HAL_GPIO_Init(LED_YELLOW_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
void vPrintStringToUart( const char *str )
    HAL_UART_Transmit( &( huart3 ), ( const uint8_t * )str, strlen( str ), 1000 );
/* configUSE_STATIC_ALLOCATION is set to 1, so the application must provide an
 * implementation of vApplicationGetIdleTaskMemory() to provide the memory that is
 * used by the Idle task. */
void vApplicationGetIdleTaskMemory( StaticTask_t **ppxIdleTaskTCBBuffer, StackType_t **ppxIdleTaskStackBuffer, uint32_t *pulIdleTaskStackSize )
/* If the buffers to be provided to the Idle task are declared inside this
 * function then they must be declared static - otherwise they will be allocated on
 * the stack and so not exists after this function exits. */
static StaticTask_t xIdleTaskTCB;
static StackType_t uxIdleTaskStack[ configMINIMAL_STACK_SIZE ];
    /* Pass out a pointer to the StaticTask_t structure in which the Idle task's
     * state will be stored. */
    *ppxIdleTaskTCBBuffer = &xIdleTaskTCB;
    /* Pass out the array that will be used as the Idle task's stack. */
    *ppxIdleTaskStackBuffer = uxIdleTaskStack;
    /* Pass out the size of the array pointed to by *ppxIdleTaskStackBuffer.
     * Note that, as the array is necessarily of type StackType_t,
     * configMINIMAL_STACK_SIZE is specified in words, not bytes. */
    *pulIdleTaskStackSize = configMINIMAL_STACK_SIZE;
/* configUSE_STATIC_ALLOCATION and configUSE_TIMERS are both set to 1, so the
 * application must provide an implementation of vApplicationGetTimerTaskMemory()
 * to provide the memory that is used by the Timer service task. */
void vApplicationGetTimerTaskMemory( StaticTask_t **ppxTimerTaskTCBBuffer, StackType_t **ppxTimerTaskStackBuffer, uint32_t *pulTimerTaskStackSize )
/* If the buffers to be provided to the Timer task are declared inside this
static StaticTask_t xTimerTaskTCB;
static StackType_t uxTimerTaskStack[ configTIMER_TASK_STACK_DEPTH ];
    /* Pass out a pointer to the StaticTask_t structure in which the Timer
     * task's state will be stored. */
    *ppxTimerTaskTCBBuffer = &xTimerTaskTCB;
    /* Pass out the array that will be used as the Timer task's stack. */
    *ppxTimerTaskStackBuffer = uxTimerTaskStack;
    /* Pass out the size of the array pointed to by *ppxTimerTaskStackBuffer.
    *pulTimerTaskStackSize = configTIMER_TASK_STACK_DEPTH;
* @brief ETH MSP Initialization
* This function configures the hardware resources used in this example
* @param heth: ETH handle pointer
* @retval None
void HAL_ETH_MspInit(ETH_HandleTypeDef* heth)
  if(heth->Instance==ETH)
  /* USER CODE BEGIN ETH_MspInit 0 */
  /* USER CODE END ETH_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_ETH1MAC_CLK_ENABLE();
    __HAL_RCC_ETH1TX_CLK_ENABLE();
    __HAL_RCC_ETH1RX_CLK_ENABLE();
    /**ETH GPIO Configuration
    PC1     ------> ETH_MDC
    PA1     ------> ETH_REF_CLK
    PA2     ------> ETH_MDIO
    PA7     ------> ETH_CRS_DV
    PC4     ------> ETH_RXD0
    PC5     ------> ETH_RXD1
    PB13     ------> ETH_TXD1
    PG11     ------> ETH_TX_EN
    PG13     ------> ETH_TXD0
    GPIO_InitStruct.Pin = RMII_TXD1_Pin;
    HAL_GPIO_Init(RMII_TXD1_GPIO_Port, &GPIO_InitStruct);
    /* ETH interrupt Init */
    HAL_NVIC_SetPriority(ETH_IRQn, 5, 0);
    HAL_NVIC_EnableIRQ(ETH_IRQn);
    HAL_NVIC_SetPriority(ETH_WKUP_IRQn, 5, 0);
    HAL_NVIC_EnableIRQ(ETH_WKUP_IRQn);
  /* USER CODE BEGIN ETH_MspInit 1 */
  /* USER CODE END ETH_MspInit 1 */
* @brief ETH MSP De-Initialization
* This function freeze the hardware resources used in this example
* @retval None
void HAL_ETH_MspDeInit(ETH_HandleTypeDef* heth)
  /* USER CODE BEGIN ETH_MspDeInit 0 */
  /* USER CODE END ETH_MspDeInit 0 */
    /* Peripheral clock disable */
    __HAL_RCC_ETH1MAC_CLK_DISABLE();
    __HAL_RCC_ETH1TX_CLK_DISABLE();
    __HAL_RCC_ETH1RX_CLK_DISABLE();
    PC1     ------> ETH_MDC
    HAL_GPIO_DeInit(GPIOC, RMII_MDC_Pin|RMII_RXD0_Pin|RMII_RXD1_Pin);
    HAL_GPIO_DeInit(GPIOA, RMII_REF_CLK_Pin|RMII_MDIO_Pin|RMII_CRS_DV_Pin);
    HAL_GPIO_DeInit(RMII_TXD1_GPIO_Port, RMII_TXD1_Pin);
    HAL_GPIO_DeInit(GPIOG, RMII_TX_EN_Pin|RMII_TXD0_Pin);
    /* ETH interrupt DeInit */
    HAL_NVIC_DisableIRQ(ETH_IRQn);
    HAL_NVIC_DisableIRQ(ETH_WKUP_IRQn);
  /* USER CODE BEGIN ETH_MspDeInit 1 */
  /* USER CODE END ETH_MspDeInit 1 */
/* USER CODE END 4 */
/* USER CODE BEGIN Header_StartDefaultTask */
  * @brief  Function implementing the defaultTask thread.
  * @param  argument: Not used
  * @retval None
/* USER CODE END Header_StartDefaultTask */
  /* USER CODE BEGIN 5 */
  /* Infinite loop */
  for(;;)
    osDelay(1);
  /* USER CODE END 5 */
  * @brief  Period elapsed callback in non blocking mode
  * @note   This function is called  when TIM6 interrupt took place, inside
  * HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment
  * a global variable "uwTick" used as application time base.
  * @param  htim : TIM handle
  * @retval None
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
  /* USER CODE BEGIN Callback 0 */
  /* USER CODE END Callback 0 */
  if (htim->Instance == TIM6) {
    HAL_IncTick();
  /* USER CODE BEGIN Callback 1 */
  /* USER CODE END Callback 1 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
@tony-josi-aws and @htibosch Does it mean I should not run the .ioc file and hence keeping the main.c from over-written by .ioc ?
But in this case, I will need to add the missing FreeRTOS files manually ?
@iftikhares
As mentioned in the readme you need to clone the project with --recurse-submodules or do a git submodule update --init --recursive
The project is not configured using the CubeMX tool; instead, the Kernel and +TCP files are manually added to the project, hence the ioc file may not be up to date.
If you write your code in between USER CODE BEGIN and USER CODE END, they are not overwritten by running .ioc.
I am able to compile and program the device, However it is not getting the expected address from the network. Here is the Serial Port info.
@iftikhares
Have you verified that the GPIO settings used in these functions, HAL_ETH_MspInit and HAL_ETH_MspDeInit are as per the design of the development board you are using? You can either check with the schematics of your board (available is ST’s user manual for the board) to confirm or let the CubeMX tool of ST generate it for this project or a new project and use those generated definitions in place of the existing.
Are you connecting the Ethernet cable after the MCU is started with the firmware, or is it already connected when the MCU is starting? Check if the behavior is different the other way, try if you are able to ping that default IP address.
Also, are you connecting the other end of the Ethernet cable to a router or a PC?
For more debug context, try setting the ipconfigHAS_DEBUG_PRINTF to 1 here.
