I am developing with FreeRTOS on Microzed, using Vivado 2015.1.
And I’m interested in FreeRTOS+TCP indeed.
I would be grateful if you could send me the hardware project of FreeRTOS+TCP for Microzed Xc7z010.
Regards
Did we already send you the project for the ZC702 (the larger Zynq
evaluation board)? If so that should also run on the MicroZed. As far
as I know only the GPIO pin used for the LED output needs to be changed.
Nothing outside of the Cortex-A9 core is used, so you should be able to
use the default/standard hardware definition for your board. If you add
the hardware definition to the project, then create a BSP for your
hardware definition (both through the Xilinx SDK tools - those steps are
not FreeRTOS specific) then you can switch the application project (the
FreeRTOS+TCP project) to use the new BSP.
– Did we already send you the project for the ZC702 (the larger Zynq
– evaluation board)?
Is that download codes in page of “FreeRTOS+TCP and FreeRTOS+FAT Source Code”?
If not, please teach me where I could download the project.
Thank you for sending the FreeRTOS+ project for Zynq.
I cannot build it at the moment, because “uncached_memory.h” and the relating files are not found. Could you tell me where they are ?
