I think the FreeRTOS PlugIn for IAR’s Embedded Workbench was displaying the Q stuff OK until maybe 7.3.0? Or maybe it was 7.4.0?
The debugger just says this now even though I have all of the correct #defines, etc. enabled as before:
Use the vQueueAddRegistry() API
function in the source code to make
a queue visible in this table.
Anyone else seeing this? The tasks part of the plugin seems to be fine - just the Q stuff stopped working.
Maybe this was due to the new Q functionality?
I am running the latest released EW430 v5.51.6.
Note I have spoken to IAR and they told me FreeRTOS was responsible for the PlugIn maintenance. I spoke to IAR at the Embedded Systems Conference last month and I thought they told me IAR was responsible - but I must have misunderstood.
Thanks (Richard)!
John W.
Westmoreland Engineering
This is a known issue and there is an updated plug-in that should fix the problem. I have sent it to somebody at IAR for them to confirm it works on their particular platform (AVR) but not heard back. I will send it to you also. I know it works on 32-bit architectures, if it works for you on the MSP430 then I think it should be good to go. You will receive a separate email with the plug-in.
The plug-in is now maintained by High Integrity Systems. lf the download link on their website has not been updated yet then try emailing them on support AT highintegritysystems DOT com to obtain a copy.
