manofhope wrote on Saturday, September 26, 2015:
Hi everybody,
I am a Student, and i have received the job, first to get used to FreeRTOS and make it run on the ZedBoard and later develop some applications.
First managed to run a BareMetall “Hello World” on the Board, which i generated from a template inside of the SDK. The result of the print printed out in a serial terminal.
My next step was to get a FreeRTOS Demo run on the Board. Therefore I imported the provided Projects (HW, BSP, Application) to the SDK. But neither the BlinkyDemo, nor the FullDemo run. The Application builds without any errors or warnings.
A Debugging Session shows, that the Board crashes somewhere during the bootsequence. I’ve copied the executed Codelines:
_vector_table:
B _boot
(... Debugger jumps)
#if XPAR_CPU_ID==0
/* only allow cpu0 through */
mrc p15,0,r1,c0,c0,5
and r1, r1, #0xf
cmp r1, #0
beq OKToRun
OKToRun:
mrc p15, 0, r0, c0, c0, 0 /* Get the revision */
and r5, r0, #0x00f00000
and r6, r0, #0x0000000f
orr r6, r6, r5, lsr #20-4
00000004: stclvc 4, cr0, [r10, #-376]
The last Step with 00000004 is the last executed Step. afterwards the Debugger wount step any further. And if i click ‘run’ to the next breakpoint nothing happens.
This behavior shows with FreeRTOS V8.2.2 and V8.2.0 (or, i tried only these two).
My duedate is coming closer and i am absolutly cluless, what i should do to solve this problem.
I hope anybody can help me with this one.
