girishkumar wrote on Thursday, February 14, 2019:
Hi I am tring to get FreeRTOS working on Intel Galileo board Gen2,
I followed the instruction in FreeRTOS.org and at the locaton https://sourceforge.net/projects/freertos/files/FreeRTOS/Utils/FreeRTOS_Intel_Quark_Docs/
1, I updated the firmware usign arduino IDE
2.Installed the linix image with (RTOS in //kernal ) on the SD card as per instructions using diskpart
3. Connected Galileo board to laptop using FTDI cable
4. Powered up the board. But the Laptop is not detecting Galileo board. I amnot able to use Putty or Tera Term to connect Gaileo board. I can see the LED blinking.
Can any one give me some clue on Debugging this problem - Where do I Start the debugging from ?
Regards
Girish
