surjashis wrote on Friday, September 04, 2009:
Hi all,
I am using the LWIP-Port on the ATUC3A s/w framework 1.4.0 with FreeRTOS on my hardware (custom board). Which is designed according to the EVK1100 board.
I want to use the Ethernet MACB MII interface, I am using the same PHY DP83848I with a 25MHz crystal!
In the conf_eth.h file i have changed the define
#define ETHERNET_CONF_USE_RMII_INTERFACE 0
Also I have the added the MACB interface lines to the MACB module in the ethernet.c file
AVR32_MACB_MDC_0_PIN
AVR32_MACB_MDIO_0_PIN
AVR32_MACB_RXD_0_PIN
AVR32_MACB_TXD_0_PIN
AVR32_MACB_RXD_1_PIN
AVR32_MACB_TXD_1_PIN
AVR32_MACB_RXD_2_PIN
AVR32_MACB_TXD_2_PIN
AVR32_MACB_RXD_3_PIN
AVR32_MACB_TXD_3_PIN
AVR32_MACB_TX_EN_0_PIN
AVR32_MACB_RX_ER_0_PIN
AVR32_MACB_RX_DV_0_PIN
AVR32_MACB_TX_CLK_0_PIN
AVR32_MACB_RX_CLK_0_PIN
AVR32_MACB_CRS_0_PIN
AVR32_MACB_COL_0_PIN
i am using PLL n MCK = 48 MHz
What else should i do?
It is not working, thanks in advance!
