FreeRTOS+lwip on lpc1833 controller.
jayeshbhoi wrote on Tuesday, October 07, 2014:
I have ported the lwip stack on LPC1833 microcontroller(ARM cortex-M3). There are total 6 tasks in my application. This controller communicate with another device in which standard linux network stack is running. The communication is working fine for some minutes and after that it will continues in loop in task “prvIdleTask”. In this task it call the “prvCheckTasksWaitingTermination” and in which following condition always fail
while( uxTasksDeleted > ( unsigned portBASE_TYPE ) 0U )
//some code
So, it will never enter in “while…loop” and not switch the task.
I am using freeRTOS V7.3.0 and lwip v1.4.1.
Can any one have idea about what is wrong here?
Regards,
Jayesh
rtel wrote on Tuesday, October 07, 2014:
Here is a copy of the answer I just posted on the other forum on which you posted the exact same question:
"If the idle task is running then there are no application tasks that are able to run - so all your application tasks are blocked on something or are simply delaying.
Inside the idle task it is checking to see if any tasks have been deleted in order that it might clean up the RAM allocated to those tasks by the kernel. If no tasks have been deleted then it will not enter the loop. I think that is explained in the comments above the code you pasted. Is there any reason you think it should enter the loop?"
jayeshbhoi wrote on Wednesday, October 08, 2014:
is any way to know in which task it’s stuck OR which tasks are blocked?
For your information the lwip’s tcp ip thread have highest priority 4, other two task have priority 3 and remaining three tasks have priority 2.
rtel wrote on Wednesday, October 08, 2014:
You can use FreeRTOS+Trace to visualise the behaviour. There are also
several kernel aware state viewer plug-ins. If you are using the
LPCXpresso IDE then I think the Eclipse plug-in will work for you.
I manually check the task status by using eTaskStateGet function and found that two task are in block state,1 task is suspended state and other 3 are in ready state.
So can suggest me why always running idle task?
There is of course no way I can deduce that without actually studying
your source code, and even then it would probably take some time to work
it out, but my first suspicion would be that you have not set the
interrupt priorities correctly.
FreeRTOS - Open Source RTOS Kernel for small embedded systems
RTOS for ARM Cortex-M
