fedex03 wrote on Saturday, May 11, 2019:
I’m working with a Nucleo-STm32F767 and I had generated the code with CubeMX including FreeRTOS 9.
My code has 5 task and each task has a loop, where the task is suspended on each iteration.
while( 1 )
//Do something
osDelay(TASK_MAIN_DELAY_MS);
At this point my system works well.
Now I added a task that handle the communication with an SPI network controller. The network controller has it own middleware written in C.
Now every time I try to suspend a task (with osDelay) my code is stucked into prvCheckTasksWaitingTermination and my system is blocked forever.
static void prvCheckTasksWaitingTermination( void )
/** THIS FUNCTION IS CALLED FROM THE RTOS IDLE TASK **/
#if ( INCLUDE_vTaskDelete == 1 )
BaseType_t xListIsEmpty;
/* ucTasksDeleted is used to prevent vTaskSuspendAll() being called
too often in the idle task. */
while( uxDeletedTasksWaitingCleanUp > ( UBaseType_t ) 0U )
vTaskSuspendAll();
xListIsEmpty = listLIST_IS_EMPTY( &xTasksWaitingTermination );
( void ) xTaskResumeAll();
if( xListIsEmpty == pdFALSE )
TCB_t *pxTCB;
taskENTER_CRITICAL();
pxTCB = ( TCB_t * ) listGET_OWNER_OF_HEAD_ENTRY( ( &xTasksWaitingTermination ) );
( void ) uxListRemove( &( pxTCB->xStateListItem ) );
--uxCurrentNumberOfTasks;
--uxDeletedTasksWaitingCleanUp;
taskEXIT_CRITICAL();
prvDeleteTCB( pxTCB );
mtCOVERAGE_TEST_MARKER();
#endif /* INCLUDE_vTaskDelete */
In particular, the execution is stopped here: while( uxDeletedTasksWaitingCleanUp > ( UBaseType_t ) 0U ) becuase uxDeletedTasksWaitingCleanUp is equal to 0.
I don’t know how to resolve this issue
Anybody can help me?
Thanks and best regards, Federico
