FreeRTOS+IO
Dear FreeRtos,
I would like to use your IO lib but I cannot find any files that are implementing. it (e.g. FreeRTOS_IO.h). Where can I find your implementation?
There is an old example downloadable here https://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_IO/Demo_Applications/LPCXpresso_LPC1769/NXP_LPC1769_Demo_Description.html#Download_Link but note the library is being deprecated in favor of this Common I/O - FreeRTOS
Hello, unfortunatelly this download link ist not available anymore.
Is it possible that you/someone can share the example zip?
Thank you in advance
I would recommend you start here - GitHub - aws/common-io-basic: A basic set of I/O libraries for pins and serial communications on embedded devices.. This will be receiving support going forward.
