blewis9993 wrote on Thursday, September 28, 2017:
We are trying to use the FreeRTOS+IO with i2c in a FreeRTOS project. We have the file system, usb stack and so forth working without problem with FreeRTOS. According to the product description, the FreeRTOS+IO i2c driver is easy to use so we went down that path but have hit a wall.
The FreeRTOS+IO example code base is built against a board product from NXP which is the LPC17xxx. However we have a custom board that uses the MK20dx256VLL10 processor. The problem is the bsp file set that is needed to use FreeRTOS+IO with our processor. We cannot find any documentation on how to set up the bsp files. We are using the pin_mux.c,h files generated by MCUExpresso and the SDK v3.2. These are already setting up the configuration of the processor. FreeRTOS+IO appears to want to set mux.pin structures in the bsp as well. This would be a conflict.
Can anyone share a bsp file for kinetis that works, or direct me on how to integrate the i2c driver correctly please? We invested a lot of time and money to move away from MQX to FreeRTOS because of the bsp and other dependencies. This has always proven to be a very weak link in their code base. We are hoping this is not true for FreeRTOS+IO, but need help around this area.
Thanks for any advice and help.
Robert Lewis
