nobody wrote on Wednesday, January 11, 2006:
Hi
I’m using freertos whith at91sam7a3 microconrtoller. I’d like to know wich peripherals are used by freertos. In particualar, wich timers (0,1 or 2) are not used by freertos?
Hi
By default the PIT is used. Take a look at the function prvSetupTimerInterrupt() in port.c. You can change it to use something else if you want.
Thanks a lot!!
Can I find your answer into the site http://www.freertos.org/ ? I did not find it.
By
