kammce wrote on Thursday, January 31, 2019:
Is there a version or method of using FreeRTOS+FAT without requiring malloc? Is there a static version of this library?
heinbali01 wrote on Friday, February 01, 2019:
I’m afraid that FreeRTOS+FAT depends on dynamic allocation.
It does not call pvPortMalloc() directly, in stead it lets you define ffconfigMALLOC():
#define ffconfigMALLOC( uxSize ) pvPortMalloc( ( uxSize ) )
The cache memory though can be declared statically. See :
typedef struct xFF_CREATION_PARAMETERS
uint8_t *pucCacheMemory; /* User provided memory, or use NULL to malloc the cache memory. */
uint32_t ulMemorySize; /* Size of the cache memory, must be a multiple of 'ulSectorSize'. */
} FF_CreationParameters_t;
The creation parameters will be passed to :
FF_IOManager_t *FF_CreateIOManger( FF_CreationParameters_t *pxParameters, FF_Error_t *pError )
The cache memory is used as data buffers between driver and disk. Each block of cache is 512 bytes long.
