I’m using FreeRTOS kernel on a new silicon based on ARM Cortex-M33. I am using the ARM CMSIS RTOS APIs and underlying is the FreeRTOS kernel. With the minimal blinky setup,
the application is crashing in prvTimerTask. The following is the stack trace where the crash occurs:
Thread #1 57005 (Suspended : Signal : SIGTRAP:Trace/breakpoint trap)
HardFault_Handler() at startup.S:170 0x10276a
<signal handler called>() at 0xffffffbc
prvTimerTask() at timers.c:549 0x101da4
vPortSetupTimerInterrupt() at port.c:346 0x100610
The crash happens after the scheduler is started and it does not execute any tasks. The FreeRTOSConfig.h has the following definitions:
* Map the FreeRTOS port interrupt handlers to their CMSIS standard names. */
/* Ensure Cortex-M port compatibility. */
#define SysTick_Handler xPortSysTickHandler
I have not configured any other timers and expect to use the SysTick for the FreeRTOS tick. What could be wrong ? Any points on debugging this further are appreciated.
On the hardfault, the INVPC bit of the SCB->CFSR is set.
