kapukiran wrote on Saturday, December 14, 2013:
How can I determine CPU load in Tms570ls3137.
rtel wrote on Saturday, December 14, 2013:
The answer to this is similar to the answer to your other post regarding the +Trace tool. All you need is to configure a timer that can provide a high resolution time base. This time rather than use the trace tool though you provide macros to feed the time base into FreeRTOS’s internal run time stats gathering.
http://www.freertos.org/rtos-run-time-stats.html
kapukiran wrote on Monday, December 16, 2013:
I use Tms570ls3137 and I configured configGENERATE_RUN_TIME_STATS as 1 but I did not understand How can I configure portCONFIGURE_TIMER_FOR_RUN_TIME_STATS() and portGET_RUN_TIME_COUNTER_VALUE() for Tms570ls3137…Can you give me an example.
When I configured configGENERATE_RUN_TIME_STATS as 1, t took a error.
–error If configGENERATE_RUN_TIME_STATS is defined then portCONFIGURE_TIMER_FOR_RUN_TIME_STATS must alsa be defined.portCONFIGURE_TIMER_FOR_RUN_TIME_STATS should call a port layer…
kapukiran wrote on Tuesday, December 17, 2013:
How can I configure a timer for Tms570ls3137…
rtel wrote on Tuesday, December 17, 2013:
As per the documentation page linked above you need to define one macro that initialises the timer and one that reads from the timer. How you do that on any particular part is specific to that part (not a FreeRTOS question) and requires that you read the datasheet for the part, or look for drivers that already exist for the part. In your case TI provide the HalCoGen tool that will provide the drivers you require.
