Hi everyone,
i read the documentation about the Run Time Statistics, and i didnt understand everything about it.
is there an already existing implemented timer for this macro portCONFIGURE_TIMER_FOR_RUN_TIME_STATS(), or should i make it by my self and how to implement it.
because there is no example how to implement the timer for it.
All you need is a time source that is fast enough. It has to be a lot faster than the tick interrupt for stats with a good resolution. How the time source is generated is very dependent on the peripherals that are available on your chip so you will need to configure that yourself.
We cannot provide support on using MSP430 specific hardware timers, but the macros and functions that need to be implemented, along with a couple of examples for other architectures, is provided here:
… although I presume you have seen that already. You can also search the FreeRTOS/Demo directory for other examples of where the macros portCONFIGURE_TIMER_FOR_RUN_TIME_STATS and portGET_RUN_TIME_COUNTER_VALUE are used.
Hi Richard,
my questions were not about the direct implementation. but i am asking to have more information than the information in the descrition.
like: where should the macro vTaskGetRunTimeStats() be called? in every task or only one time in one task and it will gather the statics about every other task?
from desciption in this site: http://www.freertos.org/rtos-run-time-stats.html
i understand that this macro must be used to configure the timer only but in the first example it was used to set the variable to 0 and the other macro portGET_RUN_TIME_COUNTER_VALUE to get the value of this variable. that is why, i am a little confused.
That function is used to generate a human readable table of gathered run time stats. You can call it from any task that needs this information. It is normally used to output the information to a web server or console for viewing by the user.
vTaskGetRunTimeStats() does not gather the statistics, it only formats them into a human readable table. The kernel itself gathers the run time statistics if configGENERATE_RUN_TIME_STATS is set to 1. If configGENERATE_RUN_TIME_STATS is set to one then the kernel tries to call portCONFIGURE_TIMER_FOR_RUN_TIME_STATS() once during start up, then portGET_RUN_TIME_COUNTER_VALUE() on each task switch. That is why you have to define the portCONFIGURE_TIMER_FOR_RUN_TIME_STATS() portGET_RUN_TIME_COUNTER_VALUE() to do the right thing for your hardware (you define them, but you don’t call them, the kernel calls them).
vTaskGetRunTimeStats() does not set anything to zero, in the example portCONFIGURE_TIMER_FOR_RUN_TIME_STATS() sets a variable to zero (for that particular implementation) because it is called once at start up it does the initialisation. The other macro returns the value because it is called during a context switch to return the current time value.
modiallen, it is so simple… vTaskGetRunTimeStats() is called once if you want have stats.
portGET_RUN_TIME_COUNTER_VALUE must return counter value that is 10 to 100 quicket than FreeRTOS ticks. In example on the site you mentioned is a timer register, thats why it is just variable simple macro. In my implementation it is a variable too, but in configure function i am configuring hardware timer which increment that variable with proper frequency, to get good stats…
thank you a lot richard. now i got it.
i implemented it like this:
i implement a timer that will cause an interrupt 10 times faster than the interrupt from the scheduler. and increment a variable every time this interrupt occured. and the macro portGET_RUN_TIME_COUNTER_VALUE only return the value of this variable.
i think now it must work. but i am getting nonreasnoble stats now.
all tasks have the absolut time “u” or the percentage values “u” %.
what does this “u” mean here?
as i told the last time, the Statistics, that i am getting are only “u” for almost every task except the idle task.
what does this “u” mean? undefined?
hey,
thank you for your reply.
the compiler must be configured to support printf to get the values. but i cannot do it due to the limited size that i have now in my application. i am reading it manually with the support of breakpoints.
