davidcarro wrote on Monday, December 10, 2018:
I would like to know if FreeRTOS plugin is compatible with IDE “AC6” that I am using at work and which is Eclipse based.
Thank you very much for your attention.
rtel wrote on Monday, December 10, 2018:
If the IDE uses GDB, then you can use the basic StateViewer plug-in from
the URL https://www.highintegritysystems.com/StateViewer (NOTE!!! that
is the URL you enter into Eclipse’s “Help->Install New Software” menu
item, NOT a URL you can click.
There are also some fully thread aware plug-ins for FreeRTOS you can
find on the web. One is from Segger, and another from Code Confidence -
Google will probably find them.
