Hi
I am new on the freeRTOS.I want to build freeRTOS source code for the im6ul(NXP) application processor.I am using NXP’s imx6ul-evk board for my development.I build CORTEX_A9_RZ_R7S72100_IAR_DS-5 demo code on IAR but debug controller is not comming on the main() function call.So plz tell me how can i build this code for imx6ul application processor.
You are attempting to run code that targets a Renesas processor on an
NXP processor. While the ARM Cortex-A core might be the same between
the two processors, the peripherals, clocks, etc. will not be, and
therefore the start up code, initialisation code, etc. written for the
Renesas processor are not going to work on the NXP processor.
The first thing to do is create a simple hello world application for
your NXP processor and check that can be built, downloaded and executed
on the NXP processor before adding in any FreeRTOS code. Do you have
such a simple non-FreeRTOS project running yet?
Thank you very much for your instant reply.
I have printed hello world without usnig freeRTOS on imx6ul-evk board.But my question is how can i use freeRTOS codes for my processor.Please tell for my processor which freeRTOS demo code will be use.
Thanks
Atma
