I am working on a project which involves FreeRTOS and Mars board i.MX6 Dual( with ARM cortex A9). Since i am a very beginner in FreeRTOS i am not sure how it works with ARM Cortex A series processors. I wanted to buy a book in FreeRTOS website and found the books for PIC, Cortex M series and LPC17xx. I did find some information on working with ARM A processors, but expecting a book or tutorial from ground level. Need more suggestions.
The books are really ‘how to design and use’ rather than how to port, but if you are a beginner will be helpful. The new “mastering” book is currently being given away free with other purchases as it is not fully edited yet. That comes with more than 20 (I think) examples that run using the free version of Visual Studio (so the compiler is free and you don’t need any special hardware) and take you through the very basics up to some more complex design examples.
If the i.MX6 has an ARM GIC (Generic Interrupt Controller) then there should really be no porting as such that needs to be done - its just a matter of creating a project and the Zynq (also a dual core Cortex-A with GIC) can be used as a reference.
