Has anyone made freertos + mplabx 1.20 + NVM support work?
i can get NVM to work just fine, but when I start using freertos, it locks up…
It locks up at NVMErasePage for starters…
Again, I used the sample code microchip provides for NVM support, and it works fine. I add the rtos code that was working 100% fine before NVM support, and it locks up…
Here is the code from the example…if I plop this WORKING code in my RTOS (working) program, it locks up at Erase…
* NVM Simple Example
* FileName: nvm_basic.c
* Dependencies:
* Processor: PIC32
* Compiler: MPLAB XC32
* MPLAB IDE
* Company: Microchip Technology Inc.
* Software License Agreement
* The software supplied herewith by Microchip Technology Incorporated
* (the “Company”) for its PIC32 Microcontroller is intended
* and supplied to you, the Company’s customer, for use solely and
* exclusively on Microchip PIC32 Microcontroller products.
* The software is owned by the Company and/or its supplier, and is
* protected under applicable copyright laws. All rights are reserved.
* Any use in violation of the foregoing restrictions may subject the
* user to criminal sanctions under applicable laws, as well as to
* civil liability for the breach of the terms and conditions of this
* license.
* THIS SOFTWARE IS PROVIDED IN AN “AS IS” CONDITION. NO WARRANTIES,
* WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
* TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
* PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
* IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
* CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
* $Id: nvm_basic.c 9390 2008-06-16 23:43:04Z rajbhartin $
* $Name: x.x $
#include <stdlib.h>
#include <plib.h>
// Configuration Bit settings
// SYSCLK = 80 MHz (8MHz Crystal/ FPLLIDIV * FPLLMUL / FPLLODIV)
// PBCLK = 40 MHz
// Primary Osc w/PLL (XT+,HS+,EC+PLL)
// WDT OFF
// Other options are don't care
#pragma config FPLLMUL = MUL_20, FPLLIDIV = DIV_2, FPLLODIV = DIV_1, FWDTEN = OFF
#pragma config POSCMOD = HS, FNOSC = PRIPLL, FPBDIV = DIV_2
#define SYS_FREQ (80000000L)
// PFM KERNEL AND USER MODE MAPPING
// Virtual Address Physical Address
// 0xBFC0_2FFF or ***************** 0x1FC0_2FFF
// 0X9FC0_2FFF * *
// * Boot Flash *
// 0xBFC0_0000 or * *
// 0x9FC0_0000 ***************** 0x1FC0_0000
// * Optional *
// * User Program *
// * Flash *
// 0x7D00_0000 + * * 0xBD00_0000 +
// BMXPUPBA ***************** BMXPUPBA
// * Program *
// * Flash *
// 0xBD00_0000 or * *
// 0x9D00_0000 ***************** 0x1D00_0000
#define mInitAllLEDs() {TRISA = 0; LATA = 0;}
#define mLED_1 LATAbits.LATA2
#define mLED_2 LATAbits.LATA3
#define mLED_3 LATAbits.LATA6
#define mLED_4 LATAbits.LATA7
#define mLED_1_On() mLED_1 = 1;
#define mLED_2_On() mLED_2 = 1;
#define mLED_3_On() mLED_3 = 1;
#define mLED_4_On() mLED_4 = 1;
#define mLED_1_Off() mLED_1 = 0;
#define mLED_2_Off() mLED_2 = 0;
#define mLED_3_Off() mLED_3 = 0;
#define mLED_4_Off() mLED_4 = 0;
#define mLED_1_Toggle() mLED_1 = !mLED_1;
#define mLED_2_Toggle() mLED_2 = !mLED_2;
#define mLED_3_Toggle() mLED_3 = !mLED_3;
#define SYS_CLK 72000000L
#define NVM_PROGRAM_PAGE 0xbd008000
#define NVM_PAGE_SIZE 4096
unsigned int pagebuff[1024];
unsigned int databuff[128];
int main(void)
unsigned int x;
// Configure the device for maximum performance but do not change the PBDIV
// Given the options, this function will change the flash wait states, RAM
// wait state and enable prefetch cache but will not change the PBDIV.
// The PBDIV value is already set via the pragma FPBDIV option above..
SYSTEMConfig(SYS_FREQ, SYS_CFG_WAIT_STATES | SYS_CFG_PCACHE);
// Initialize the Led Port
mInitAllLEDs();
// Fill databuff with some data
for(x =0; x < sizeof(databuff); x++)
databuff[x] = x;
// Erase second page of Program Flash
NVMErasePage((void *)NVM_PROGRAM_PAGE);
// Write 128 words starting at Row Address NVM_PROGRAM_PAGE
NVMWriteRow((void *)NVM_PROGRAM_PAGE, (void*)databuff);
// Verify data matches
if(memcmp(databuff, (void *)NVM_PROGRAM_PAGE, sizeof(databuff)))
// If not turn led1 on to indicate an error
mLED_1_On();
// Write 0x12345678 to Address NVM_PROGRAM_PAGE + 0x200
NVMWriteWord((void*)(NVM_PROGRAM_PAGE + 0x200), 0x12345678);
if(*(int *)(NVM_PROGRAM_PAGE + 0x200) != 0x12345678)
// Turn led2 on to indicate an error
mLED_2_On();
// Write the pagebuff data to NVM_PROGRAM_PAGE + NVM_PAGE_SIZE
NVMProgram((void *)(NVM_PROGRAM_PAGE + NVM_PAGE_SIZE), (const void *)databuff, sizeof(databuff), (void*) pagebuff);
if(memcmp(databuff, (void *)(NVM_PROGRAM_PAGE + NVM_PAGE_SIZE), sizeof(databuff)))
// Turn led3 on to indicate an error
mLED_3_On();
return 0;
I’m don’t know the NVM routines in the PIC32 libraries. Are they writing to the flash memory from which the kernel is running? If so, to do that are the routines that perform the erase and writes either RAM functions or written to RAM first? If so then any interrupts that try to run from flash during the erase/write cycles could cause you a problem.
