Sir,
i was tried to write a freertos code for lpc 1768 in keil …it did not compile atall .i was used ARM_CM3 port.c and portmacro.h file from the folder RVDS .
i got freertos 7.2 example code for lpc1768 (keil) from githubs it was builded, compiled and downloaded into the target device.
i used same freertos7.2 v files (task.list queue.port frertosconfig.freeros.portmacro) to create, it was working.
please do tell me how to create a new project for lpc1768 in keil and build in freertos9.0 and explain which and all files i want to use.
or
please send me one of the example you created for lpc1768 in keil.
compile atall
You would need to tell us what you did, and what the compilation errors
were.
Wow - that is old.
Why not get the official code from us, we could support it then. As it
is I don’t know where you got the code from or if it has been modified.
it was
I’m confused. Is the code building or not? I thought you said it
didn’t compile at all.
The following link tells you which files you need to build:
