I’m new at FreeRTOS and I’m working with Eclipse Luna for C/C++ on PC with windows 8. I’ve imported the FreeRTOS Demo Project as described and everything worked fine.
Now I want to see the trace recording of the demo. I’ve installed FreeRTOS+Trace but I don’t know how to export the memory to a dump file so I can open it with FreeRTOS+Trace. The memory view in eclipse doesn’t show any data.
Any idea how to do this?
Thanks
The top right of the memory window has a row of icon/buttons. One of those icons is “1010” with an arrow pointing up at to the right - hover over it and it says “Export” - press it and you can define a region of RAM and a file name you would like to save the RAM too. You should be able to use the name of the trace recorder buffer variable as the start address, and just make the size much bigger than it needs to be (as the +Trace tool will know where the start and end are).
