darshu wrote on July 05, 2018:
I am using Amazon FreeRTOS on ESP32 Devkit C. The normal Amazon FreeRTOS is compiling fine.
I have added additional components such as CAN and Bluetooth.
CAN functionality is working as expected.
As I am trying to create a GATT server for BLE, I have added some more folders of the component directory of esp-idf such as esp32, soc and drivers to the espressif-code folder of AFR.
Now, I am getting this error when compiling:
LD build/aws_demos.elf
C:/AmazonFreeRTOS/demos/espressif/esp32_devkitc_esp_wrover_kit/common/application_code/espressif_code/esp32/lib\libpp.a(pp.o): In function `ppResortTxAMPDU':
(.iram1+0x16fc): undefined reference to `xQueueGenericReceive'
(.iram1+0x174e): undefined reference to `xQueueGenericReceive'
C:/AmazonFreeRTOS/demos/espressif/esp32_devkitc_esp_wrover_kit/common/application_code/espressif_code/esp32/lib\libpp.a(pp.o): In function `pp_create_task':
(.text.pp_create_task+0x160): undefined reference to `xQueueGenericReceive'
C:/AmazonFreeRTOS/demos/espressif/esp32_devkitc_esp_wrover_kit/common/application_code/espressif_code/esp32/lib\libcoexist.a(coexist_core.o):(.iram1+0x3c): undefined reference to `xQueueGenericReceive'
C:/AmazonFreeRTOS/demos/espressif/esp32_devkitc_esp_wrover_kit/common/application_code/espressif_code/esp32/lib\libnet80211.a(ieee80211_ioctl.o):(.text.ieee80211_ioctl+0x4): undefined reference to `xQueueGenericReceive'
C:/AmazonFreeRTOS/demos/espressif/esp32_devkitc_esp_wrover_kit/common/application_code/espressif_code/esp32/lib\libnet80211.a(ieee80211_ioctl.o):(.text.ieee80211_ioctl+0x77): more undefined references to `xQueueGenericReceive' follow
collect2.exe: error: ld returned 1 exit status
make: *** [/C/AmazonFreeRTOS/demos/espressif/esp32_devkitc_esp_wrover_kit/make/../../../../lib/third_party/mcu_vendor/espressif/esp-idf/make/project.mk:394: /C/AmazonFreeRTOS/demos/espressif/esp32_devkitc_esp_wrover_kit/make/build/aws_demos.elf] Error 1
I am confused because, error is in .a (lib) file.
What is the possible solution?
Edited by: darshu on Jul 5, 2018 4:21 AM
